Twowheeletex baja build, finally.
- twowheeletex
so I've been plugging away, slowly. I ran in to a little snafu recently when I was told to remove it from the parking lot where I've been working on it in. It's now safely at a co workers house. here are some pictures of my progress.
new tires for the front. the wheels and tires on the rear are from my rail.
replaced the bent beam with one from a junk yard. nicely enough it's adjustable.
all the lights are installed and operational. still some wiring left to do. waiting on an exhaust I ordered, and floor pans.
but there she is so far. I won't have floor pans till the first of the year.
- twowheeletex
so I got a welder for christmas, means I can finally put in my floor pans. just have to go pick them up from the parts house. also traded for some suitable exhaust. put all that in, tidy up some wiring and replace the brake lines and I'll be in business. I'm sure there's more, but that'll get me running down the road. anybody whose put in a few sets of pans. is there any tips you have?
- twowheeletex
- twowheeletex
so I traded the sandrail for some goodies
- twowheeletex
so the project has had some setbacks but it is still in the works. I have some updates. the pictures are taken at night with my cell phone so sorry for the poor quality.moneypit wrote:So have you left this thing for dead in Shane's driveway? What's the news?
Beuhler?
I have moved the bug some fifty miles from the co-worker house I previously mentioned. it is now 25 miles north of base in a far more work friendly environment. I pulled the body and removed the floor pans only to find the forward bulkhead was garbage. so I ordered a new one. I wanted to wait until it came to hack the old one off. once I did cut it off I had to cut a piece of the lower bulkhead on the passenger side because it was eaten through.
I used some of the good metal in the upper part of the bulkhead to fabricate the lower piece I removed. all in all it turned out well. be easy on the welds. I was using a 110 volt flux core and it's been a while.
I welded the bulkhead in yesterday and just finished welding the new floor pans in just after dark this evening. I do not have pictures of that yet. more to come tomorrow. hopefully I can have this thing in good enough shape to take around the block one or twice before I deploy in the very near future.
- twowheeletex
I put the body on today. by the time I got the bolts all tightened down it was dark and the mosquitoes where so bad, so no pictures of the fit. the pictures I do have are of the front bulkhead welds and the floor pans in place. I took these as I was lowering the body onto the pan because I only remembered at the last second. here they are.
pictures of the fit tomorrow probably. also I'll try to remember to take pictures of the welds on the underside of the pans.
- rickosuave1987
Looking good.
I have no clue on the carb either, but if you can find some manifolds that will bolt up to them i dont see why you couldnt make it work?
Baja
HookIt
SuaveRacing FaceBook
HookIt
- twowheeletex
- twowheeletex
so i got the body bolted on, all the fuel and brake lines run. the car starts runs and i even took it out yesterday. the only problem is RH rear brake cylinder is shot, so no brakes for the moment. before anyone gets up in arms about me driving with no brakes, the emergency brake works. as far as going around the neighborhood the whole area is sand, including the roads. it's 5 miles of clay road out to the house and the sand roads around the neighborhood are loose enough to offer plenty of breaking power.
here is a picture of the clay road.
I plan on having pictures up tomorrow and maybe a video.
the engine runs like a champ but the body needs some more love. when driving over washboard sections of road it sounds like the whole thing will rattle apart at any moment.
though it's really rough right now and nowhere near close to finished, there is that awesome feeling of accomplishment. I brought a rust bucket pos that was left for dead to a running driving pos.
- moneypit
It's a good thing that the pictures are blocked on the *cough* "work" computers because I'd probably make much fun of your welds. It's all in good fun, though. Did you get the engine for my Squareback running yet? Actually, never mind the engine- is the car still there? I haven't asked about it in ages!
Either way... glad to at least READ that some progress is being made! Thow a new wheel cylinder on it and take it for a rip through the sand before you get here- cuz once you get here you'll be thinking "man, my baja would be sooo much fun here!"
- twowheeletex
