So this is frustrating. With the initial positioning of the VR sensor the other day I had what appeared to be a solid ~300 rpm cranking tach signal. So I did some clean-up on the shroud (and repainted same) and mounted the TR on the fan (as shown by Devastator).
Next step was to set the tooth #1 Angle (under Trigger Wheel Settings). I did this by disabling fuel (unplugged the injectors) and had Mrs Max crank the starter while I watched the timing light. I had set the Number of Coils to "Single Coil" for this and connected pin36 to the stock coil. Although the signal seemed ratty, I put that down to the stock rotor/cap and installed the shroud and exhaust.
Then I started the car. Ran pretty nasty, with the tach reading reasonably but intermittantly dropping to zero. I still have the stock coil/distributor supplying ignition but the tach misbehaviour also screws up fueling.
So I figured I might be getting interference from the ignition, so I depowered the coil and just got a short log just cranking. Same thing. This zip has my CurrentTune plus the MLV and also an ignition log (first time I've used that).
http://www.maxwelton2k.net/squareback68 ... ntTune.zip
So I think I may have screwed up the VR sensor position while I was working on the shroud, having ruled out EMI from the ignition. I will now have to remove the exhaust and bellows again to see what I did. That's what I get for being impatient.
Unfortunately it is no easy thing now to adjust the sensor position.
Here are the pictures:
http://www.maxwelton2k.net/squareback68 ... index.html
Max
