Re: Type 1 twin screw supercharger build / 9 yrs later I'm back at it
Alexander_Monday
Post by Alexander_Monday »
Holy cow, almost 0.006" new?
That is over D × 0.0025.
I'd be sending them back, unless it was pro stock or top fuel.
Made a lot of aluminum swarf tonight.
Guess what they are:
The older I get, the faster I was.
Alexander_Monday
Wow, Speedway Motors doesn't mess around shipping, got the King CR 803XPN SBC small journal narrowed rod bearings today!
So nice when something measures exactly as advertised:
(I only opened the first package of 8 and all except 1 which was 0.0620")
Vs the Mahle CB-610A bearings:
This will give me 0.0017" clearance with 1.9991" journals which is D * 0.00085.
Unfortunately, I will have to make a jig to take 2mm off one side of each bearing.
Can't have my cake and eat it too, but my bad since they are advertised as 20mm wide while the Mahle's are 18mm wide)
Alexander_Monday
Designed a jig to narrow the bearings on the lathe.
3D printing it now.
Alexander_Monday
Jig worked really nice in the lathe.
Just a touch of chatter because it is plastic.
Before:
After:
I have another printing that is narrower to use to relieve the edges.
Alexander_Monday
Alexander_Monday wrote: Wed Apr 02, 2025 5:54 pm Holy cow, almost 0.006" new?
BTW, the big aluminum jigs I made awhile back are for this:
(Not ready for that yet, but I have the jigs made)
Alexander_Monday
Cut down SBC small journal rod bearings before clean up in narrow 2nd jig
After file and stones to clean up
Alexander_Monday
Decision time.
Should I measure end play with tension on the crank or not?
What is acceptable for a flanged crank?
I have seen .005 to .008 preferred and .010 to .014 preferred.
This is a street warrior engine, not a drag race only engine.
Crank installed with Brad Penn assembly lubricant and case nuts tightened.
End play with 1/4" wrench turning big screwdriver against crank away from Flywheel end
Let tension off
Holding tension toward flywheel end
Let tension off
Alexander_Monday
From Mark Lawless:
"Your thrust measurement is right on the money."
Alexander_Monday
BTW, Pat Downs sells HP SBC small journal rod bearings already narrowed.
If I would have known, I would have bought them from him.
https://shop.patdownsperformance.com/products/bearings
Alexander_Monday
Long story short, the conversion stub axles rub on the inside of the trailing arm.
Putting a 30mm x 44.5mm x 0.5mm shim I found between the inner bearing and the inner race for the seal stops the rubbing.
I want to put 2 on each side but only found 3.
They were in with my VW saved stuff not used.
Anyone know what they are actually for so I can get more?
panel
Re: Re: Type 1 twin screw supercharger build / 9 yrs later I'm back at it
Post by panel »
Kinda look like swing axle washers that fit behind the seals.
Alexander_Monday
Are they that thin?
Someone else suggested the same.
Funny though, never had a swing.
Alexander_Monday
The second side took 2 to stop rubbing so I decided to use 2 for it and 1 for the other side.
Stub axles changed, freeway flyer out and KCR "best parts type 1" unboxed.
Alexander_Monday
Didn't get as far as I hoped, but transaxle installed, Bowden tube adjusted, shift coupler hooked up, stub axles installed.
CV's & axles another day, this old man is beat after lawn work, mowing, and working on this.
Alexander_Monday
Is this normal radial play for brand new parts?
It is total play for both sides.
The slop appears to be in the EMPI axle splines.
