Going Honda
Re: Going Honda
Here is the piece that bent. We had a little stress behind it.
Here is where I am at now. I’m calling it good, as far as straight. Have to zoom in past the Jack.
Re: Going Honda
Leather, I would clean up those rough sawn edges on the side cuts and break the sharp corners a bit as they are weaknesses. Also, stress does not like to jump and bounce around, it likes a flat surface to slide along.
fordfreak
Re: Going Honda
Post by fordfreak »
Leatherneck wrote: Sun Nov 22, 2020 2:50 pm Here is a vid of it going limp mode at 3k vice the 2 K.
https://youtu.be/LD8osRnRNLw
My Honda does that sometimes. When you starve the oil pick-up there's some air bubbles or pockets that run through the VTEC solenoid manifold and it kicks it into limp mode. Just a quick flip of the ignition switch fixes it. Also check your oil screen behind the oil filter housing... Bet there will be gunk in it. Any small restrictions love to lick it into limp mode!
Re: Going Honda
It is crazy what can slow this engine down, in my case it was a connection that wasn’t pushed all the way in. Took it for a ride today, VTec and all. Good googley moogely that is one sweet smooth ride. A steady fast gain on speed then a kick in the butt when VTec kicks in. Woowza
CentralWAbaja
Re: Going Honda
Post by CentralWAbaja »
Haha good description.
Re: Going Honda
While I had some time I put the correct air cleaner on it.
The stock starter was good on the VW, on the Honda it was not so much. So Hi-torque starter was installed. Big difference.
blue1957
Re: Going Honda
Post by blue1957 »
ill be returning to this thread soon hopefully for some referencing.
Re: Going Honda
blue1957 wrote: Fri May 28, 2021 1:20 pm ill be returning to this thread soon hopefully for some referencing.
You won’t regret it, what fun change this has been. Should of done this long time ago.
Skidmark
Re: Going Honda
Post by Skidmark »
We all have our personal learning curves, Leather...
"Your car sounds angry, and it wants to go fast all the time..."
(quote from my daughter, after driving my car)
It's not complicated, it's just expensive...
Re: Going Honda
Skidmark wrote: Fri May 28, 2021 6:29 pm We all have our personal learning curves, Leather...
😂😂😂😂. I am slow but I do get there.
Devastator
Re: Going Honda
Post by Devastator »
Glad you are enjoying the engine swap. FWIW, the insulation on my Hi-torque starter started peeling off after a few months, exposing the bare wire as a potential short when I start the engine. Fortunately, (and miraculously), the bare wire is not near anything on my rig to short out when I start the engine, but I'd suggest you keep a a sharp eye on it.
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
Skidmark
Re: Going Honda
Post by Skidmark »
That pic of the weld you posted looks really good. You should try using anti-splatter spray, though. Makes it much cleaner and much easier to knock those weld berries off.
shifty2006
Re: Going Honda
Post by shifty2006 »
Any update? Is this thing back on the road??
Re: Going Honda
Leather ran it in a race not too long ago, might be in another thread.
I'm still using a vw gear reduction starter, 9 tooth from a tdi or vr6 automatic, early-mid 2000s vintage
Takes a couple minutes with a rattail file to get the bolt holes in the right place, but it cranks my new-2-me 49k 10.5:1 cr 3.6l subaru in my vanagon at ~500rpm, sounds as fast as a compression test with no plugs...essentially same speed as a low compression 1.8l t4... 12 new ex seats, proper 3 angle valve job, excellent compression...starter doesn't care. (ex seats were badly pitted, common Subaru thing apparently)
Re: Going Honda
Buggy is doing great, 1000 miles on it and it runs like a dog who touched an electrical fence.
I do have some noise coming from the transmission strange noise I am trying to locate. Don’t think axles but close to it. When you lay on the gas the engine wakes up and screams. 😎😎😎
