Re 13.5: It seems happiest there, and I cannot make this knock regardless of how hard I have tried.
Short of actually putting it on a dyno,(using TS calculated HP/TQ) making it richer just seems to suck more fuel.
The initial 10 degrees of cold adder is ~all out by the time the CHT hits ~250F.
Despite my best efforts, AFR calibration could also easily be off 2-3/10ths as I'm still running analog between the WBO2 and the MS. I need to stick a NB in and see how close it checks out at stoich targets.
I plan on doing 96s this summer largely in order to bump the compression, although I may put 1.7L heads on it instead. (and cut down the jugs to fit the heads/use 93mm flattops)
WTD: Timing/ignition table for Megasquirt
Re: WTD: Timing/ignition table for Megasquirt
- TouringBubble
So am I just running the most aggressive spark table of anyone on here? I mean, it's only 9.5:1, but I surely thought there would be people pushing beyond what I'm doing.
Follow my SCCA Rallycross build on Facebook.
Dirty '73 Beetle. 2109cc with way too much intake.
Power numbers to come.
Sponsors: Satellite Racing - Defined Performance
Steve Arndt
Depends on your definition of aggressive. More isn't better with timing. Minimum timing for best torque is the safest and best tuning method.
http://www.google.com/#q=minimum+timing+best+torque
Steve
My Baja Build
My Baja Build
- TouringBubble
I understand minimum best torque, but I also understand the knock limitations of 93 octane fuel. I've monitored tq output and it increased with timing, so I'm not at MBT and I'm also not at the knock limit.
