VW Engine Build-Off Input Request
Post by MASSIVE TYPE IV »
It's all about timing for me....
The SCCA Run Offs are at that same time of year and I have to support my guys while they are going for the gold (On TV)
Chico Performance Racing
Post by Chico Performance Racing »
Ok these is the same list the builder's will getting good luck
Official Dyno event rules
1. 2332cc or smaller type 1 engine
Standard 94mm bore no head stud off set allowed.
2. VW OEM head's or equivalent (example's GO1-GO2-G03-CB044-040-041)
One spark plug per cylinder,Air-cooled type1 head,welded head ok (no super flow wanna bee)
OEM valve guide location no relocating allowed
OEM valve covers must be used
3. 5.7 connecting rod on shorter VW-Chevy-Porsche journal only
4. 2'' exhaust header or smaller must have a muffler.
No stingers
5. Carbs IDA,IDF,DRLA,SOLEX 52mm or smaller only (linkage must be ready to just hook to cable nut)
No F.I system of any allowed
Engine must have a stock or electric fuel pump mounted to engine or AN - 6 on carbs( Makes it alot easier to hook on dyno)
6. Intake manifold any
can be welded no taps of any on intakes
7.Distributors must be in it's location Mallory,Bosch,MSD allowed
Mags ok but must work off dist drive pinion only
8.One fan belt only must be from crank pulley to alternator or generator
fan must be in place, no electric cooling of any can be used,no fan clutch system.
No power pulley,serpentine pulley's ok,fan must turn with crank pulley
9.Standard 36mm oil pump or smaller, no dry sump system of any allowed
no external oil cooler allowed,filter base and oil filter only.
10. 4qt deepsump or smaller
11.All sheet metal must be in place
must have doghouse style oil cooler type1 oil cooler or type 4 oil cooler only
12. NO vacuum pump of any allowed.
13. No type of turbos,superchargers, or N.O.S allowed no added gases or injection system allowed other then 91 octane 100% carbs
14. tappered camshaft any grind with solid lifter or ceramic only (no roller)
15. 35 min max on dyno so have her ready highest number's are recorded. Rpm range 3500-4500-5500-6500
In event for sure
1. Geoff Hart (AZ)
2. Steve Tims (CA)
3. Shawn Moore (CA)
4. Brothers VW machine Shop (CA)
5. James Beahm (GA)
6. CB Performance(CA)
7. Clyde Berg (CA)
8. Victor Menjivar (CA)
cnavarro
Post by cnavarro »
How about a sustained 50 HP load @ 3500 rpm, like Eric suggested? It's a great real world test that holds more in my book that raw HP figures, assuming that there will be real data acquisition, like head temps, egt, etc. Even if you just monitored a single head temp, the senders are dirt cheap and everyone should be forced to run the same sender.
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
dstar5000
Post by dstar5000 »
WOW! Let's see who can build the best Type I engine....BUWAHAHHAHAHA!
:roll:
Again, no Type 4 allowed.......we wouldn't want to spank those TI guys
in an engine buld-off, now would we?
:twisted:
I thought you guys wanted diversity, you know, "ten different configurations", was posted somewhere in this thread....
You're ending up with 8 2332 clones, just built by different folks.
:lol:
Good luck guys!
8)
Don
Eaallred
Post by Eaallred »
Limitations create immitations.
Eric Allred
1963 "Street Legal" Drag Bug
MegaSquirt 3 Crank Fire EFI
CTACH
Post by CTACH »
Ill put my money on Geoff Hart Racing.
dstar5000
Post by dstar5000 »
Eaallred wrote:Limitations create immitations.
DAMN! You summed up my entire post in three words?
:lol:
Don
Gareth
Post by Gareth »
:lol:
Don
Verbosity is played out...
:lol:
Eaallred
Post by Eaallred »
lol
Eric Allred
dstar5000
Post by dstar5000 »
BUWAHHAHAHAHHAHAHAHAHA!
:twisted:
Don
turbo_bob
Post by turbo_bob »
Eaallred wrote:94 limit; 96mm pistons
I personally have bee pushing for a cc limit instead of a bore and stroke limit that way the Type 4 guys could play since 96's are fairly common.
The type 4 2.0 engine uses 94 mm bore stock.
I think that thowing a TIV in the mix would do nothing but create even more headaches for Chico when trying to create a more level playing field.
I would LOVE to put together something for the event, but I know that with the differences between TI and TIV that the rules that would be fair to each engine would be damn near impossible to create..
This looks like it may be an annual event, so let's see how it goes this year for Chico and maybe next year he can take what he learned from this first event and apply it toward a set of more universal, but "fair" rules.
Eaallred
Post by Eaallred »
And a Type 1 engine uses 85.5 mm bore stock. But they have been allowed all along to run larger than stock bores that are common. My point being, 96mm bore is common with Type 4's, so why not let them run it?
As far as a "level" playing field, i'd throw that in the garbage. Make it as un-level as it wants to see what variety shows up to play. Like stated earlier, make it a showcase, not a contest. Show the spectators what kinds of DIFFERENT things can be accomplished to reach the same goal.
Eric Allred
JohnConnolly
Post by JohnConnolly »
oh brother. The field is level when you say "2300cc limit, get it however you want". A bunch of clone motors is going to put readers to sleep.
I WOULD be interested in a 2270 T-4 (78 X 96mm), 2300 T-4 (69 X 103mm), 82 X 94mm T-1, 88 X 90.5mm T-1, etc That would be cool!
John
Aircooled.Net Inc.
turbo_bob
Post by turbo_bob »
Larger bore, equals larger valves, equals more H/P.
