turbo oiling
69bug
turbo oiling
thanks marty...appriciate the answers...i think u also answered my other question in the vw drag racig forum tooo. i have another quetion in that forum if u could answer ...thak u...
- Muffler Mike
turbo oiling
Hay all, im back from my life, LOL
had to show off the new born to all the reletives this weekend.
But the good thing, Marty covered every thing.
Hay Marty, taking the dragster out again soon?
Muffler Mike
www.MufflerMike.com
Muffler Mike
www.MufflerMike.com
- Marty
turbo oiling
Mikeyyyyyy!
Wasssuuupppppppp??????????????
It just so happens that we will be taking the dragster up to Palmdirt this weekend for the import race. The IDRC tech guy called me the other night asking me if I would be there. Pretty cool people. They arent the VW bashers that everybody thinks they are.
Got the turbo back together and the new 350 GPH fuel pump in.
Lloyd is also going to try to run the Manx in All Motor. We will probably just make exibition passes in the dragster but if they do something nice for us maybe I will run the buggy while Lloyd drives the dragster. We'll see but I'll definately be there Saturday.
See if you cant drag your old a$$ up there.
www.staggsracing.com
[This message has been edited by Marty (edited 11-26-2001).]
- Muffler Mike
turbo oiling
I just might have to do that.
those guys left a message on my machine as well. VERY cool.
i wish my car was ready. i wont be ready to test until early-mid january.
im craving the race thing again.
Muffler Mike
www.MufflerMike.com
Muffler Mike
www.MufflerMike.com
69bug
turbo oiling
some questions on the pics...
please help!!!!!
some other ones on the bottom post too!
please help!!!!!
69bug
turbo oiling
here are the other pics...the questions are on the pics...
please help!!!!!!
thank u!
please help!!!!!!
thank u!
- Marty
turbo oiling
Ok,
The little threaded hole (1/8" NPT I think) is the oil inlet. The larger untapped square hole that looks dirty inside and is on the exact opposite side of the oil inlet is the oil drain. You need a tapped adapter for the drain that will bolt on with the two bolt holes beside it.
Your turbo looks to me to have a water cooled center section. Thats what the other two holes are for. I think you can just plug them but I would talk to a REAL turbo guru to make sure. This must have come off a water cooled car of some kind.
gatorvws
turbo oiling
It looks like that turbo came off a late '80s chrysler lebaron. It basically the same turbo that volksnut is using.
On pic #1 yes that is the oil return, you can also go to the wrecking yard and adapt the original piece for your drain.
Pic 2 is the oil inlet as previously stated opposite from the outlet.
Pic 3&4 are the water inlet and outlet. which you have two options a. plug them (the easiest) or to install a small cooler with fan and and electric pump and plumb it for cooling. (too much bs to contend with)
As for the orientation of the intake and exhaust. See volksnut pix ontaking it off. the exhaust you might whant to do the same and going with an external waste gate (sorry I forgot where the accuator is mounted on the intake. Also the waste gate is probably set around 8#s.
Hope this helps
Alan
p.s. also on the exhaust it is set up for a factory donut with sprung bolts attaching it. so you might want to pick up the factory down pipe ata wreckling yard also.
"Hot rodding is mega ingenuity - not mega bucks"
[This message has been edited by gatorvws (edited 11-29-2001).]
Hope this helps
Alan
69bug
turbo oiling
gatorvws...where can i see the pics that volksnut has on taking it appart.
gatorvws
turbo oiling
He doesn't have any pix on taking it apart, but here are a couple showing what he did do to it.
http://www.geocities.com/thevolksnut/turbo.html http://www.geocities.com/thevolksnut/45dcoe.html
Alan
Alan
turbo55joe
turbo oiling
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by 69bug:
<B>THE PICTURE I POSTED ISN'T MINE...IT'S A.J. SIMS(LOWBUGGET.COM)...I PUT THE WRONG ONE IN
THIS IS THE ONE I WANTED TO SHOW U GUYS</B><HR></BLOCKQUOTE>
Sorry guys!! I have not been on this site for awhile. I have been busy with other projects. The blue turbo bug is mine. Its an old school De Coppen Bros. set with a Rajay EF-80. I used a tee fitting and a 90 were you would normally put your oil pressure sensor, because I also have my oil pressure sender for my pressure gauge and my AutoMeter pro light sensor that goes to my warning light. So from engine oil pressure sensor outlet to turbo oil inlet. Then it is gravity drained to were I use to have the stock gas pump with a fuel block off plate with a 1/2 hose fitting using 1/2 braided house. In the picture that was Sacramento race way in May. I drove my car from San Jose to Sacramento that day with no problems, but on the way home I was 3/4 the way home and incountered tranny problems up the grade in Pleasanton/Fremont. I was stuck in 3rd gear and thought I bent a shift fork or something. Thanks to Art Masunaga and the guys from the Road Relics VW Club for helping me get out of a bad situation. We pulled Arts show car out and put my car in his inclosed trailer and got my car home safely. I left the car alone for a week and tried to figure out in my head what went wrong. I finally pulled the bumper off and took of my rear apron cause I was going to take the motor and tranny out. It ended up that one of the bolts for the shift coupler was loose. I checked it that day but that little movement makes all of the difference in the world. I even had it safety wired so it won't come out, but it had loosen alittle bit. I tightened it and moved my shifter around and started the car and all gears were there. Wuhh!! Problem Solved!
69bug
turbo oiling
does anyone one know where there's a good turbo rebuild shop in the chula vista are
if you can't find't it...GRIND IT!!!
