Harney's diatribe - rocker geometry to install & beyond
mharney
Ah.. I get it Ryan, those are similar to if you've milled the bottoms off - I think those must be close to a 0.150 difference (closer to the head) from the looks of it. I measured mine, and the top thickness was about 0.100, and the bottom close to 0.245. These look just about mirror image of one another in your picture, so that would change it by about 0.150" for the ones you have.
Wow.
Wow.
- 64 variant
mharney
- 64 variant
mharney
Ok, I found a way to drop the rockers in (flipped the blocks over and made a set of non-shouldered studs for temp use from some old studs I had). After about a 0.060" drop, I have interference at the head studs, and at the block pads/rockers, and I still would not have enough "drop" from pulling them in if I went to 0.100". I'd have to offset down as well as in to get them right, cut all my studs, and have the heads clearanced.. may as well have the pads on the heads clearanced and have the studs reloacated down a little.
Screw it. I'll try different rockers. Bulletins as they occur.
mharney
Hijacking my own thread.. how fun.
So I am clearancing my universal case by hand for a 76mm CB crank plus stock rods, for my upcoming bus engine.. I've noticed there is considerably more clearancing to do next to the cylinder bore for the oppsing rod when doing the right hand case half. Is this common?
Also my pickup tube is really junky. It looks like a smaller tube with a lousy bend in it, flattening the tube out a bit at the bend, and the entrance is at a wierd angle picking up from the sump. Is it possible to source a GOOD larger tube, and have the opening in the case resized to accept it?
