why build a T5 and not A T4
"T5" USES T1 heads...
If you have a wasser motor, and are thinking "turbo" I suggest you might just think about keeping it water cooled, particularly if it is indended to be a driver.
The ability to have REAL HEAT practically for free is a nice bonus.
The wasser heads flow well, (or can be made to do so) and they tend to stay on under boost. They just need real work if you are revving >7500 or wild lifts.
Even a 1.9 is a "factory 1914", put some H-beams in an otherwise stock setup, and blow.
Perhaps some ARP head studs..
Even all stock internals have held up to some rediculous boost.
I know the radiator is a PITA...
pocketrocket
Post by pocketrocket »
Vtec this:: Mike, The vanagon block is a die cast not sand cast as with the new brazil cases. It comes with a 1.5 sump built right in. It has a full flow feature oil system. Now the bad part it is not cheap to re-machine the block & do it right. Use a 94mm P&c kit with a 86 stroke. That way you can use bug type heads. With the 101.6 P&Cs you would have to use a head like the AutoCraft 910s. Rocky
vtec this
Post by vtec this »
I saw some of those 910's on the samba for $5,000!!! that is pretty wild. i think i will stick with the stock setup minus the watercooling. I would like the max stroke out of it since i am limited to 94mm pistons. i think there is someone in the Netherlands with a 90mm full circle crank in one? I guess i should not speak like that. my budget will determine what goes into this engine. in that case, more realistically speaking, i can get the jackets cut, and runn 94's on what ever crank that is in there. So is it $900-1300 to cut the jackets and put in the spacer for type 1 cylinders at Rocky Jennings?
thanks-mike
Max keltvik
Post by Max keltvik »
I have a 90mm in a 2.1 case. It drops in! The cam is the only problem. I'm lookingt in how to make a t-1 (044 and S/F) head fit the 101.6mm cylinders. :wink:
pocketrocket
Max, When you say it drops right in what rods are you using? The crank will go in but how much do you have to clearance for the rods. Use a junk cam die grind it to see how much needs to be taken off for it to clear the rods. Rocky
Max keltvik
Scat 5.7" rods is on the 90mm crank, the cam is made to fit (TSC 30). I have a set of alu Pauter 6" rods that's taking the Scat's place soon.
pocketrocket
Max: The alum. pauter rods are over 2mm .090 wider on the big end. That means you will have trim .045 more off the cam. How wide are the scat 5.7s the pauter alum 6.0 are 3.340 wide. Rocky
Max keltvik
The Scat's are 80.5mm/3.169". I'm going to trim the Pauters to fit the cam... :roll:
_INDY_
Post by _INDY_ »
would you trade 2 1.9 and 3 2.1 blocks for 1 block that is ready to go? :D i got a tonne(litterally) of blocks i can't use cos noone around here knows nothing about vw's :?
pocketrocket
Max do you have the pauter rods? Be very carefull on how & how much you take of the cam as it will be very thin & weak if not done right. Rocky
Max keltvik
Yes I have the Pouters. I'm going to make the rods fit the cam, not make the cam fit the rods...
pocketrocket
_INDY_ who are you directing your questions on the blocks you have. Rocky
pocketrocket
Max don't know if you can safely take much off the aluminum beam rods they are pretty thin as it is. Good luck. Rocky
