PJMS wrote:
There are two reasons why I cannot go along with the results, just because they have been done. Firstly, I believe they were too specific. Secondly, I believe that the results are now being repeated in too general terms, leading people to make sweeping judgements. There is an implied responsibility here. I am sorry that Jake has to go through the frustration of 'doubters', but that is also the cost in doing that kind of work. If you are right, then it will come out in time and, if you are wrong, then thank goodness we are not all sheep. Anyway, just because no one has seen the 'VW data' does not mean that it does not exist. This idea that no proof means simply 'myth' does not carry water with me.
Your first reason-
When you say "too specific", do you mean the fact that its on a dyno and not in a car? If you do then I think you are mistaken. Jake is doing side by side testing. If his goal was to, "keep all head temps under 350", then yes it would be too specific. But, he is only testing which one cools better and more evenly compared to other shrouds, including stock.
Your second reason-
I think I know what you mean, but it really has nothing to do with the tests, if I understand correctly. I read stuff that other people say about how the 36 horse shroud did the best, and how everybody needs to get one, even though the actual manufacturer of the shroud is still unknown (to the general public). Every time I see this, I make a point to say that it was one specific 36 horse shroud, and you can't expect to bolt on any ol' 36er and get the same results.
Steve
