Posted: Tue Jan 27, 2004 11:35 am
After looking at a couple of driveshafts on some websites you can clearly see that each end should be paralell to the other end. If not you have a driveshaft that have vibrations, because even if the input rpm is steady the output side of the shaft will have different speed on different points of one round. Good luck! //Roland
