I CAN BREAK ANYTHING!!
Roland
Post by Roland »
After looking at a couple of driveshafts on some websites you can clearly see that each end should be paralell to the other end. If not you have a driveshaft that have vibrations, because even if the input rpm is steady the output side of the shaft will have different speed on different points of one round. Good luck! //Roland
Patte
Post by Patte »
That`s correct Roland.Looking at a STD or a hi po aftermarket driveshaft you can see that Jake has placed the joints the wrong way.I hope Jake has mounted the new shaft correctly,or it`s gonna break at some point again.
Locked
