the 924 was a "de-evolution" of the 928 design
porsche engeneers designed the 928, then some of the corperate penny pinchers decided they should build a cheaper version of it from VW and Audi parts. many will say thet it turned out well, but its definatly not a 928.
Crazy Idea? Fiero Front End?
volkdent
The cut and paste front to rear transplant of the Citation front end in the rear of the Fiero is the motivation for my 1.8t transplant. It just shows it can be done.
I think I'll pass on a Chevette front end though!
Jason
Jason
1960 "Bad Dub" http://youtu.be/VEUPxTw11hk
Drag http://youtu.be/NNcPQDiNPQE
Dyno http://youtu.be/51_JRESS0Tg
1957 "Ragster" http://germanlook.net/forums/showthread.php?t=11514
- Mike T
One thing to note here is although the Held motorsports front suspension unit is made to fit a Fiero it isn't the same as a Fiero suspension. The geometry was improved to to provide good camber gain with suspension travel and reduced bump steer. It's actually very close to a true racing suspension and is offered as a handling upgrade to a stock Fiero. It should not be confused with a stock suspension.
One good thing is it's mounted in a tubular subframe and is more or less self contained. Sort of a modular suspension unit and should be adaptable to other vehicles with some fabrication.
Mike T
Mike T
Tugboat
Better check the track width. Fieros are pretty wide, 2" wider than Chevettes.Mike T wrote:One thing to note here is although the Held motorsports front suspension unit is made to fit a Fiero it isn't the same as a Fiero suspension. The geometry was improved to to provide good camber gain with suspension travel and reduced bump steer. It's actually very close to a true racing suspension and is offered as a handling upgrade to a stock Fiero. It should not be confused with a stock suspension.
Mike T
GL
