Cast vs Forged Crankshafts
Cast doesn't HAVE to suck, it just usually does.
Example:
Dodge SRT4... 101mm stroke, 50mm rod journals (same as 2.0 T4, ~itty-bitty) cast steel crank... These see >400HP++ regularly and are not known for breaking cranks.
IIRC they put out reasonably serious HP from the factory.
Read an article awhile back where one of the major tricks they use to make them live was roll forming the journal fillets rather than just cutting it.
Apparently makes for a very strong, crack resistant crank.
This same techique would probably do wonders for a welded strokers strength as well, or ANY crank for that matter, as it strengthens the weakest area of any crank.
I can pretty much guarantee no cast VW crank has this done to it.
Welded C/W stokers are cheap and plentiful, and if bought from DMS or DPR have a great reputation.
Example:
- Marty
terry cloyd
A stock VW crankshaft is made from 1045 forged steel. A Scat crankshaft is made fron E4340 steel. Cast cranks are made from poured steel. Other cranks advertised as being made from 1045 steel were, but they added sulphur during the manufacturing process (sulphur speeds up the machining process= lower cost.
I know ....so what does this mean
Yield Break
1045 forged VW 80K 120K
E4340 forged 122K 144K
Cast 18k 18k and can be as low as 11K
1045 forged/suplhur 33K 75K
Yield Break
terry cloyd
Csaba
The yield strength is the value where plastic deformation occurs when the material is (i am assuming) subjected to tensile force. Break strength is the value where it ultimately fails. An important factor to consider is the spread between the two numbers. Notice that the cast material shows yield and break at the same value. This is often referred to as a 'brittle' material, which is not suitable for quality crankshaft materials. A more ductile material, such as the 1045 forged, is more suitable, but will be less resistant to bending stresses under load than the 4340 forged. For performance applications, you want a stronger material, with a higher yield strength.terry cloyd wrote:A stock VW crankshaft is made from 1045 forged steel. A Scat crankshaft is made fron E4340 steel. Cast cranks are made from poured steel. Other cranks advertised as being made from 1045 steel were, but they added sulphur during the manufacturing process (sulphur speeds up the machining process= lower cost.
Yield Break
Csaba
terry cloyd
Csaba wrote:The yield strength is the value where plastic deformation occurs when the material is (i am assuming) subjected to tensile force. Break strength is the value where it ultimately fails. An important factor to consider is the spread between the two numbers. Notice that the cast material shows yield and break at the same value. This is often referred to as a 'brittle' material, which is not suitable for quality crankshaft materials. A more ductile material, such as the 1045 forged, is more suitable, but will be less resistant to bending stresses under load than the 4340 forged. For performance applications, you want a stronger material, with a higher yield strength.terry cloyd wrote:A stock VW crankshaft is made from 1045 forged steel. A Scat crankshaft is made fron E4340 steel. Cast cranks are made from poured steel. Other cranks advertised as being made from 1045 steel were, but they added sulphur during the manufacturing process (sulphur speeds up the machining process= lower cost.
Yield Break
Csaba
Your right.
The cast crank is like glass and can break anytime. Did you note the forged /suplhur crank is less than VW crank.
