The Ragtop Express
TPB_Karl
Re: The Ragtop Express
Post by TPB_Karl »
Piledriver wrote: ↑Mon Nov 25, 2024 7:33 am You do nice work!
I guess those inner fenders are "trim to fit"....
Thank you! :D
Yeah.. I'll try to shape them into a decent fit, and match them to be as symmetrical as possible.
TPB_Karl
Post by TPB_Karl »
A couple of short visits to the garage this weekend. Had a big convex area by the horn grill on the driver's side front fender that I couldn't get rid of. Luckily I had backup fender and i don't understand why I didn't take this one from the start... This one fit perfectly and i just had to move the turn signal hole.
Then I started on the rear fenders. On the left, the gravel guard was still there, so after removing it, the to-do list grew once again..
I considered cutting out the whole piece that was rusty and making another attempt on the English wheel. But as I've said before, these are only supposed to get the car passed an inspection, so I've started patching up instead..
The fender is not finished. Work continues next weekend.
Ciao!
TPB_Karl
Post by TPB_Karl »
Back on it!
The white rear fender had a fairly long dent that got straightened out. I also welded and drilled new holes for my taillights.
Then it was time for the last fender. It was bent and had split apart at the hole for the bumper mount. But otherwise quite solid!
It found its way home eventually.
With the fenders ready, it's time to adress the rust on the body.
TPB_Karl
Post by TPB_Karl »
Horn mount and not a hole in sight (Or so I thought)
Tax receipt and first owner's name and residence. Gunvor in Lidköping
The spare wheel well is pretty rotted out and the same can be said about the little aluminium badge..
I tried blasting it off but it was a little far to gone. Are these available as newly manufactured?
On closer inspection at the horn, I discovered that the side was very thin... So i had to make a small repair.
The problem I had with the replacement panel from IGP was the hole where you take out the shift rod. On the original, the edges were folded in and on this one there was just a hole cut out. After some measuring, CADing and 3D printing, I had a giant dimple die. The 3D print did not survive.. But I got to the hole looking decent!
After some sanding and welding primer, the front was ready to receive the new wheel well. Grinding and paint..... Tt looks quite decent though. It's not 100% finished as i'm out of sanding belts and Roloc discs for my air tools..
And as a nice addition to the shelf, The same local club member that gave me the green fender has made a another donation. This time chrome T-bars. They should add at least a couple of hp.
V8Nate
Post by V8Nate »
Nice work it's coming along!
Sent from my SM-S918U using Tapatalk
Tbars are worth at least 5mph on the top end ;->
The... distressed... look of the original aluminum tag was hard earned, I would personally retain it as a badge of honor.
TPB_Karl
Post by TPB_Karl »
V8Nate wrote: ↑Sun Dec 08, 2024 9:48 am Nice work it's coming along!
Thanks! :D
Piledriver wrote: ↑Sun Dec 08, 2024 11:01 pm Tbars are worth at least 5mph on the top end ;->
You know, i just might! Once the car is under the complete rebuild i might make a custom one.
Will its sunday again, time for an update!
I’ve cleaned up the welds and thrown some primer in the spare wheel well.
Friday, I went to the garage and sorted the hole in the floor behind the drivers seat.
This repair was done "quick and dirty". I know this is not the right way to do it.. The idea is for it to pass the MOT. Later, when the car is fully disassembled and under rebuild, the body will be lifted from the pan, and both floor halves will be replaced with new ones.
Then it was time to tackle the inner wheel arches. The right side was first, and I decided to try making the sheet metal myself instead of buying an aftermarket panel.
Of course, you start with CAD (Cardboard Aided Design).
After some bead rolling, flanging, and bending over my knee, it started taking shape.
The heater channel also needed repair (of course).
The gap at the bottom of the A-pillar was welded shut, and I made my own press tool to shape the area around the nut for the fender mount. Strangely, I didn’t take any pictures of this, but I’ve filmed the whole process.
Using some 6mm metal from the scrap bin, I made a nut that resembles the original ones, which, as I understand it, were pressed into the fender edge. This one ewas welded on the back side.
Then it got welded onto the car. The fit wasn’t 100%, but I think I can adjust it later.
Next time, it’ll be the left side.
Take care!
You do better "get it ready for MOT" work than many of the "restorations" I have seen.
TPB_Karl
Post by TPB_Karl »
Piledriver wrote: ↑Mon Dec 16, 2024 5:17 am You do better "get it ready for MOT" work than many of the "restorations" I have seen.
Thank you!
Here we go again!
I did some 3D scanning and CAD work for a friend and got paid in oil filters and Argon mix. Thanks for that!
Then I repaired the inner fender on the driver's side. The procedure is the same as on the passenger side, so here’s a bunch of pictures for you.
Got a tip to make drainage holes at the bottom of the A-pillar to prevent this part of the car from rusting again. After doing some research, it turns out that cars from ’61 already have a drainage hole that channels water out over the siderunners. The opening is right at the seam where the A-pillar’s panels overlap.
I had an idea to make a new hole at the front since I plan to give the car a bit of a nose down attitude. But that hole would end up inside the front fender, which would probably let more water in than out… So I’ll stick with the original drainage.
Here’s a little overview since about half of the rust repair work is done.
Probably won’t get more done before Christmas, so until next time, I would like to wish you all, a Merry Christmas! :D
Merry Christmas to you as well good sir, and beautiful work as always!
TPB_Karl
Post by TPB_Karl »
After exams, reports, and assignments at the university, I finally got a few days in the garage—four, to be exact!
It's time to tackle the tedious work on the rear ends of the rocker panels.
First up, some more parts for the build!
Metal behind the doors and the outer section of the rear inner fender.
2-inch shortened tie rods, shock absorbers, and new rear lower quarter panels with bumper brackets.
Here's the first side to address.
After cleaning up a bit, it’s easier to see where the problems lie.
Looks like some repairs will also be needed under the heater channel before inspection.
I’ve temporarily removed the jack mount, and the car will likely remain without it.
I started with the easier task: the lower rear quarter panels. It’s only held in place with welding clamps for now.
Carefully removing rusty parts from the front inner fender corner.
The heater channel is, as usual, in bad shape, so I made a small repair.
Eventually, I plan to lift the body from the chassis and replace the entire heat channel.
TPB_Karl
Post by TPB_Karl »
Further research showed double layers of metal at the end of the heater channel toward the rear wheel well.
Ideally, I’d lift the body to fix the entire cross member, but for now, I’m patching it as best I can.
First, the inner layer.
With that in place, I could fit the outer piece—and while at it, i gotta test a T-bar!
When everything looked good, I welded it in place.
Next up: the metal behind the passenger door.
This part will need lots of love before it’s ready to weld.
I started by cutting off the bottom section and replicating the original panel, including the drain hole.
All welded nuts were removed.
The lower part now uses a stud, and the upper part will follow the same approach as the front fender repairs.
It took some persuasion to match the radii reasonably with the original.
TPB_Karl
Post by TPB_Karl »
Unfortunately, I didn’t get further this weekend, as I spent some time on the reinforcement plate for the inner fender.
I experimented with heating and hammering a bowl into a piece of metal, smoothing it with an English wheel.
I tried 3D printing a press mold with alignment pins in aluminum but failed.
I then traced the bracket onto the plate and made one from 2mm steel.
All this was testing for the final parts.
I’ll likely skip the "bowl" and go over the bumper bracket to allow for torque bars in the future without excess metal in the way.
That’s the current situation! Work continues next week.
V8Nate
Post by V8Nate »
Excellent work!
TPB_Karl
Post by TPB_Karl »
This weekend I have been in the garage almost all weekend. However, not much progress on the car, as I was distracted by this:
AC/DC TIG weld with plasma cutter. I've never TIG welded before other than trying to add a couple of tacks a few years ago. However, I have done some gas welding, so I have an idea of what the puddle should look like.
Then another package showed up in the garage! A first iteration of a licence plate holder. I have 3D printed brackets to put under the spare tire tray with m5 lock nuts.
Looks like I might be on to something. What I'm waiting for is the front quick release as it's only with cable ties at the front for now.
The idea is to make a licence plate holder which can quickly and without tools be removed the at carshows or VW-meets. And you should be able to put it back without it ending up crooked and preferably not be able to come off while driving.
It is of course intended for us who will drive without bumpers or with T-bars or Nerfbars.
I have some changes to make for the next version. But it feels good so far.
I have also done a little bodywork. I finally gained courage to cut and fit the sheet metal behind the passenger door.
