Ah...yes.....that will happen with virtually any....if not all.....regulators. What you are seeing is the phenomena that any/every spring has a specific "cracking" or unseating pressure required. I order springs for dies and injection mold work by the unseating pressure as its critical.Steve Arndt wrote:Ray, my pressure fluctuation happens with the engine off (pump on to test) so I don't think it is influenced by injector flow. It is more like the regulator opens/closes rapidly resulting in the pressure never settling.
But.....once unseated and being held suspended off of its "seated" position.....the spring should then regulate or stabilize at a linear rate.
If you are using a regulator from another vehicle designed to run at either a much higher fuel volume or a much higher pressure range....the spring that the engineers installed my have an unseating pressure that is dangerously high.
If yours is only fluctuating +/- 2 psi when clicking on the pump....and only happens once when the pump is energized but the engine is off....its not an issue.
If with the engine off and the pump energized...it keeps fluctuating/cycling....you have either too large of a spring in the regulator.....or more likely....you are having a fuel volume issue....meaning difficulty maintaining steady fuel volume to maintain stable pressure from the pump.
If as you noted....you have gone through several different...known quality pumps and still have this problem......I would surmise that with the engine not running. ....you have low voltage to the pump causing it to output lower volume.
In other cases if you are using fuel pressure with that range of pumps that is over about 30-35 psi....I would suspedt a weak or missing check valve on the outlet side of the pump. Ray
