yvre wrote:I would chose the Engle 100.
For a turbo, I have always heard that, when in doubt, you should go for the smaller option (cam, exhaust size, etc...)
If it was n.a, I would probably go for an Engle 110 (street engine, right?). For a turbo, I would chose one size down.
You could always play with ratio rockers at a later stage if you want more lift.
FYI, I helped work on a supercharged 1776cc two years ago. Stock crank, 40*35 heads, and Engle 110.
At 6,500rpm, power was still going up...
I was planning on using a W100. I even bought one of my build. Its just sitting in my garage getting dusty. A lot of people say the W100 is good. Then again it's not a turbo cam and after reading up about overlap and how turbos dislike it I thought I would look at other options.
The guy who has been working on my heads told me that the 218 is a good turbo cam as it has less overlap. He also said that Web make better cams!
The option of running a TSC 10 only came about after I noticed that it was being used by a lot of peeps on this forum.
Found this massive list of different beetle cams and there specs online.
http://www.actionimport.com/Tech_Files/ ... mation.htm
In conclusion I'm still unsure!
