480whp 65' Bug k20 turbo, New BOR 67 incar video!!!!
capsoval
Post by capsoval »
ToRy 70 wrote:JESUS! :shock:
how big is that downpipe?
this is an awesome build.
4" with no muffler. Dont have any Idea what its going to sound like yet. Thanks for the props, but 55superbeetle gets all the credit.
My Turbo Build>> http://www.shoptalkforums.com/viewtopic ... 9&t=122882
480whp/300wtq>> http://www.youtube.com/watch?v=6-RvkpiTmr4
Special Thanks to 55superbeetle, Jeff @ 40Thirteen fabrication
capsoval
Post by capsoval »
capsoval
Post by capsoval »
ToRy 70
Post by ToRy 70 »
hey cap how much does that lump weigh? did you just add some heavier torsions in the rear or what?
capsoval
Post by capsoval »
Its about 100lbs more than the bug motor. I haven't changed the torsion bars because Im not sure if its going to need it. The rear suspension was really stiff with the bug motor. As a matter of fact it wouldn't even transfer weight with the old bug motor on slicks. Hopefully we will have its first test drive tomorrow and will get to see how things really are.
capsoval
Post by capsoval »
roachghia70
Post by roachghia70 »
Getting close!!
Did you guys end up getting it out on the road after I left on Wednesday?
capsoval
Post by capsoval »
Nope, after putting it back on the ground and double checking everything... the car wouldn't start. After checking the problem found out the Aeromotive fuel pump wasn't running. Took it apart and the magnets had come loose from the housing. We reglued them and are going to try again today.
roachghia70
capsoval wrote:Nope, after putting it back on the ground and double checking everything... the car wouldn't start. After checking the problem found out the Aeromotive fuel pump wasn't running. Took it apart and the magnets had come loose from the housing. We reglued them and are going to try again today.
Oh cool, so you found some fuel-resistant glue?
That pump has been nothing but trouble, huh?
55superbeetle
Post by 55superbeetle »
Still a long way form being "finished" but it runs and drives. Should have it on the chassis dyno within a few weeks!
http://www.youtube.com/watch?v=1HjsHYu9AhA
http://www.youtube.com/watch?v=bQpolL1IVjo
55superbeetle
panel
Post by panel »
Just stumbled on this thread. WOW! It almost looks like it's supposed to go in there. Will you run a rear apron or some sort of deck lid eventually?
capsoval
UPDATE......
Post by capsoval »
Finally got the bug tuned, wound up making 330whp on only 9psi with a very conservative timing map, am going to retune after I get a new map sensor.
Will have videos soon.
skinnyman
Post by skinnyman »
How did you get or modify the k20 to bolt on the vw transmission ??????/
looks great good luck.
capsoval
Post by capsoval »
skinnyman wrote:How did you get or modify the k20 to bolt on the vw transmission ??????/
KEP made the adapter plate, you would just have to call them as they dont list making one.
