Horizontal T4 Cooling Fan Shroud Info
Re: Horizontal T4 Cooling Fan Shroud Info
I'm unsure if that would really be much more efficient, but that pic was giggle-worthy :lol:
I suppose if you carved the housing down or remounted the guts it wouldn't look out of place.
Retaining the input v-belt is a feature.
Frallan
Post by Frallan »
That is why I wrote Wow! It meant a lot of things......I giggled a bit too. Plus that someone in fact had used the same wild concept but in "the rough"
Wally
Post by Wally »
I found this very nice germany produced horizontal fan set-up from www.orratech.de, which I really like:
letterman7
Post by letterman7 »
Wally wrote:I found this very nice germany produced horizontal fan set-up from http://www.orratech.de, which I really like:
That's purdy right there....
CobraJet
Post by CobraJet »
Purdy an 'spensive!
Max Welton
Post by Max Welton »
Very Clean!
Max
sweetlokin66
Post by sweetlokin66 »
That corvair motor is something else haha.
Frallan
Post by Frallan »
Looks very nice but I would prefer a bit more angle on the pulleys.
Maybe the picture is fooling me?
It was a common mistake some years in own built setups, to not angle the pulleys at all.
Worked fine up to maybe 4-5000 rpm but after that, belts jumps.
Frallan wrote:Looks very nice but I would prefer a bit more angle on the pulleys.
Looks like they have a tiny DS crank pulley driving things, all aligned well so the pulley setup they have will probably work fine.
(ideally you only want to change directions in one axis)
If you had a larger crank pulley the direction-changing pulleys would have to be spaced/angled to suit.
IIRC Joe Lociero once said here that back when he raced Corvairs they would add an additional idler--- just a scuff plate probably-- on the slack side to prevent tossing belts.
Frallan
Post by Frallan »
Good point, could be very correct.
Did you guys see the 3800 €uro Porsche fan system. 5100 USD!!!
Frallan wrote: Did you guys see the 3800 €uro Porsche fan system. 5100 USD!!!
Yes, very pretty, but it had better wash dishes and make great sandwiches for that sort of money.
I'm still trying to get over spending $35 on another Corvair fan...
I really need to suck it up and spend 60 on a NOS one, they get little cracks at the root of the blades.
BTW, the Corvair guys are of the opinion that the later magnesium fans fixed the belt tossing issue.
...perhaps the fix is a combination of both reduced mass and a idler to take up any slack at a critical point...
When you get a corvair fan in the mail you will swear the box is empty until you look...
craigvwdude
Post by craigvwdude »
I really like that setup!
MegaRookie
Post by MegaRookie »
My version: :D (allmost finished, now busy with the insides of the engine.)
Mark.
macdweal
Post by macdweal »
MegaRookie wrote:My version: :D (allmost finished, now busy with the insides of the engine.)
Mark.
Very nice Mark but be aware, Wally may get jealous. :wink:
tonyorlo
Post by tonyorlo »
http://www.tangerineracing.com/Engine.htm
Anyone have any experience with thier system?
