thanks for the reply, I wish i could get that mpg im my bus!!! loaded with full length roof rack i get 20. I have had the engine in a 60 rag then a 70 vert. the 70 is what got the solid 29 all the way to sacramento! I think the 412 r&p was the key to the mpg.
i am going to put this h2o system in my bus though. loade d down it does get pretty hot so my interest in the injection.
anyone else have a working setup that can chime in with dos and donts??
Water Injection: All set or all wet?
bbattey
Re: Water Injection: All set or all wet?
I know this thread is long dead but I want to share this for anyone who's interested in water injection.
Back in the 60's a GM engineer named Doug Roe was stunning the road racing world with a turbo Corvair (http://autoxer.skiblack.com/roe/roe-racer.html#mvc-017s). I remember reading that he was using water injection, but was injecting the water into the cooling air inlet at the fan shroud, not the intake inlet. Seems like this would go a long way toward keeping the heads cool without having the water go inside the engine...
- 63busguy
what about the rust? I guess painted cylinders and stainless pushrod tubes might not rust. I asked the question before and was told thermal shock would warp or crack the cylinders if they are hot.
Has anyone used water injection on a propane blow through turbo?
OwenMM
I thought about the same idea the other day, inject a fine mist into the fan inlet when the temps get up to a certain point. Might be worth looking into co2 sprays like guys spray on intercoolers to chill the air entering the cooling system? As far as corrosion goes maybe a bit of soluble oil etc could be mixed in with the water?
Shouldnt be a hard setup to rig up for a bit of testing anyway.
karol
good read about using water to help cooling aircooled engine:
http://forums.pelicanparts.com/porsche- ... ution.html
- Chip Birks
The cooling mist in the fan has been done before. Check out http://www.blackline57.com/57intexhtin.html they set up a system for a salt flats runner. Supposedly works great.
Salt flats is probably the only track where spraying any amount of water onto the track would be permitted...Chip Birks wrote:The cooling mist in the fan has been done before. Check out blackline57.com they set up a system for a salt flats runner. Supposedly works great.
- kyle_pc_75
I've seen it in person at a car show, though I missed seeing them run at World of Speed. Very slick setup, and the kids who built it were more than happy to show off and explain the whole thing.Chip Birks wrote:The cooling mist in the fan has been done before. Check out http://www.blackline57.com/57intexhtin.html they set up a system for a salt flats runner. Supposedly works great.
As for water on the track, I can't imagine any of it makes it out the back end before vaporizing, but I don't know. Track rules might still prohibit it, however.
Kyle
