VW EFI parts from México
- quickkafer
While I didn't wind up buying from Aldo, I would highly recommend him. His email communication is great!
Just as a side note, the only reason why I did NOT buy from Aldo is that I'm going with a bigger set up and the Stock Mexican system won't work for what I need. Unfortunately, I'll be spending too much money on having a custom plenum built with an intercooler.
But if you are not as crazy in the head as I am, you should definitely consider buying your Mexican EFI parts from Aldo!
Scott Faivre
Scott Faivre
AldoQ
Mexi bugs in laredo Border
HI
if any one wants a Mexi bug, i can buy here in México and put in laredo TX border , and any one can import as parts, for that the bug need to come without engine
this link is for a local news paper, if any wants to find some VW
http://avisos.elnorte.com/vehiculo.asp
regards
regards
- quickkafer
Re: example
Your link is not working for me.AldoQ wrote:for example this bug
http://avisos.elnorte.com/avisos_detallew.asp
US$4476 in McAllen or Laredo TX
Scott Faivre
Looks like a combo pump/sump, meant to be fed by a feeder pump.VWGirl wrote:good to have another source for parts for my mexi! that fuel pump looks crazy!
Nice setup.
How much does it run?
Ineresting info on Jenveys website, they indicated that a single TB of 42mm was good to >240HP in a plenum based NA setup, based on their tests, no power gain going larger. (Of course the manifold design would have to have large enough runners, big enough plenum etc)quickkafer wrote:While I didn't wind up buying from Aldo, I would highly recommend him. His email communication is great!
Just as a side note, the only reason why I did NOT buy from Aldo is that I'm going with a bigger set up and the Stock Mexican system won't work for what I need. Unfortunately, I'll be spending too much money on having a custom plenum built with an intercooler.![]()
Scott Faivre
