Or drive around like a little ol lady like me.
Chuck's Baja Build
Re: Chuck's Baja Build
A vanagon automatic doesn't cost much, not hard to rebuild, and with a K of mods will handle 500++hp all day long..
(it doesnt really need that for a Honda v6)
Its also geared right out of the box. You can get a locking diff or an lsd or a torsen diff for it as well as taller final drive ($)
It also happens to fit and will probably work with the same engine adapter you have.
(you will need a flexplate)
- chuckput
I already have a 091 box and 930 CVs. Are you thinking I would need more than that? And my driving style is more like David's (without the running into trees
- baja5
A stock 091 can last if you baby it with a Honda. Mine has Weddle internals and does ok.
- Leatherneck
- CentralWAbaja
George, George, Gorge of the jungle.....
- jt1967
Another Tree......
- chuckput
Sharp eyed Shoptalkers may notice that I have returned to a single carb setup. While dual carbs look cool and provide a punch of power, I had multiple issues with them and I just decided it was not worth it. I will hang on to the dual carb setup for now and it may make a return in the future. What I would really like to do is try fuel injection.
This weekend is the Yuma, Arizona all VW show (Volkswagens at the River). I plan to attend. It is a 60 mile freeway dash for me, and the outcome of that trip will help me decide if my bug is healthy enough to make Mark Girdner's Death Valley Trip and possibly the Mojave Road. Fingers crossed.
- mgirdner
Well, I hope it goes well for you then! It would be great if you could make either or both of our upcoming SoCal Bajas' "overlanding" trips....the Yuma, Arizona all VW show (Volkswagens at the River). I plan to attend. It is a 60 mile freeway dash for me, and the outcome of that trip will help me decide if my bug is healthy enough to make Mark Girdner's Death Valley Trip and possibly the Mojave Road. Fingers crossed.
Lurking in Covina, CA since 2002
- '69 Baja
- '73 Thing
The problem could be caused by a loose steering wheel. And you also need to check the wear of the tires. As far as I can tell, you're using a BFG KO2, which is definitely a great off-road tire.
- chuckput
dheard86, I appreciate your insight, but my post was tongue in cheek.
- chuckput
- chuckput
Mark, the obvious question after today is how did my trip to Yuma go? In a word - Nada! It seems like whenever there is some event or run I really want to go on my Bug says, "No way, Jose!" Yesterday, I took it out for a spin to make sure all systems were OK for a freeway dash to Yuma the next day. There were a couple initial hiccups, but everything seemed OK. I was having a little issue with starting that I had initially thought was related to the starter itself, but changing the starter only proved that the issue lay in the flywheel starter ring gear. Well, my Bug decided to make this flywheel problem more of a major problem because after returning home from my test drive and checking the oil, it would not strat. Even pushing the car in fourth gear to try and find a new spot on the flywheel was unsuccessful. That means I will pulling the engine this week. Luckily, I have another flywheel so we will see. I really, really want to go on your Death Valley adventure.mgirdner wrote: ↑Tue Mar 01, 2022 6:09 pmWell, I hope it goes well for you then! It would be great if you could make either or both of our upcoming SoCal Bajas' "overlanding" trips....the Yuma, Arizona all VW show (Volkswagens at the River). I plan to attend. It is a 60 mile freeway dash for me, and the outcome of that trip will help me decide if my bug is healthy enough to make Mark Girdner's Death Valley Trip and possibly the Mojave Road. Fingers crossed.
[/quote] This was interesting. Someone had used the term "Pigeon toed" a while back which is the toes pointed in not out. After reading Chuckputs post I got interested and looked it up and the medical term for it is "out-toed". I have seen people what were "out-toed" before but never this bad.
The really bad thing about this is if you were riding in the trails or the land "out west" area your spurs might lock together and there you are, stuck with no safe way to move.
Dual carbs or ITBs have one major issue...
The linkage is everything for keeping them sync'd.
The really beefy looking one everyone buys beats itself to death in a few thousand miles, adjusting it will not fix it, its a basic design issue.
A synclink is expensive, but worth it.
You can also roll your own split cable pull variation relatively easy.
This is made easier with motorcycle carbs or ITBs as a lot of carbs and ~all of the FI rigs use pulleys...
IDF webers like to funnel all debris that gets by the filters directly into the idle jets, it works so well, almost looks intentional .
Jet doctors fix that but apparently cause other issues, I just greased the filters rubber seals up with suspension bushing grease, and went to washable synthetic dry filters vs the fine silica passing gauze filters.
