200hp 1200DP Turbo 'Challenger motor'
- Kalle
Re: 200hp 1200DP Turbo 'Challenger motor'
Congrats man! 91hp corrected I pressume? The same 12% or so?
250hp from a 1300cc should be doable with a turbo.
-K-
-K-
- brewsy
Congrats!
Thats very stout and bodes well for when you bolt the snail onto it!!!
As for that Berliner....
I'll have her/him one day in the unofficial 1285cc/77mm bore class
- Wally
Tnx! Yes, already corrected for drivetrain losses.
But no, not as a percentage as its a (very) different Dyno.
It seems pretty accurate as original engines basically had original hp numbers, but other then that, its an old unit also used for trucks LOL!
- buguy
That's awesome. Triple the power it started with!
- panel
- Wally
split1950
So there is a replacement for displacement!
andy198712
That’s mega out of a 1200! What rpm did you hit and peak at?
- Wally
6275 RPMandy198712 wrote: ↑Mon Sep 07, 2020 12:46 am That’s mega out of a 1200! What rpm did you hit and peak at?
Dyno might have been a little optimistic I think, but still
Bruce.m
What spec is the “Salzburg” 1641?
Does it have any original parts or is it a cut down fan shroud on a different spec engine. Strong PS from it, so curious.
Interesting mix of engines
- Wally
Only know it has FK89 cam with 48IDA’s.. Could not be measured properly I understood, so outputnumber you saw might not be accurate..
- Wally
Well known posure for the car as dyno mule
Most fun was the original 1200 industrial engine in the buggy, where only the Empi 4-1 exhaust was put on.
The evening before, the guys brought à home made kit of parts, amongst which a GT1544 turbo and in 2,5 hours of wrenching, it made 76hp on the Dyno next day!!
Totally amazing wrenching and carb conversion skills!
Eddie010
Walter nice figures… and nice video..
Really cool nowdays…
Man 250HP on a biturbo 1300.... i say whooo
You are now going to put a turbo on the 1200 and see how much power there is?????
- brewsy
Thanks to Sascha for making the video.
Wally, your 1200 sounded mean!!
May I ask a favour? I noticed that the compound turbo 1641 Fiat was also from the Netherlands, by any chance do you know if they have a build thread?
Cheers
Cheers
- Wally
Eddie: the 1300 is a single twin scroll turbo (from a Mini)..
But yes, next year a turbo will sit on this one (hence the section this post is in
First I'll try to retard the cam a bunch to see if it will pull a little more up top and to get a good torque chart from my usual dyno place (you know the one
Good eye Marc, but sorry, the owner (Hendrik) doesn't do website write ups afaik..
I did make a picture when he took the rear apron off though
There was a lot more in it, but his injectors maxxed out and the clutch slipped heavily..
