200hp 1200DP Turbo 'Challenger motor'
- MegaRookie
Re: 200hp 1200DP Turbo 'Challenger motor'
I dont know, but I would say that the rings would maybe help a bit with heat transfer?
Ps. Maybe a bit off (this) topic, but any updates on the typ4?
- Wally
Nah, the spacer rings dont touch the liners if everything is machined ok.
No updates on the type4. New guides are in and seats get cut next week. That will start after the 1200 Challenge.
In fact, this 1200 Challenge gives more fun atm because of the rivalry with the other competitors
- Wally
Small step further: installed pistons, now waiting for some super duper CNC machined stock size intake valves
- Wally
And they came in today!
- buguy
Thin! Should flow pretty good huh?!
- Wally
Thats the idea
- Kalle
They improve flow where it matter most.
Check out the valves on the mighty impressive Cosworth CA engine. This was a low budget engine compared to its competitors but at the same time it had the longest service intervals (350-500 kilometers) and it was also the only one coping with 20000 rpms over a longer period. 305 to 315 hp per litre. It is considered one of the all time best F1 engines.
-K-
split1950
That is awesome, even just to look at itKalle wrote: ↑Fri Aug 21, 2020 1:22 amThey improve flow where it matter most.
-K-
- buguy
Interesting! Looks like more of an I-beam rod than an H-beam too. And no oil control ring on the piston?
madmike
I see the oil rings and a single comp ring,
- buguy
Ahhh. Good eye. I guess my eyes aren't what they used to be!
- Kalle
The rods on the CA engine are rather massive;
And here is a short video of it in action:
http://youtu.be/BPdm51QwZEw
-K-
andy198712
thats not exactly a "rod" its almost wider then it is long!!
- Wally
Two weeks and counting...
- Kalle
Looking good but please get rid of that pulley tensionerer. You want the belt to slip.
-K-
-K-
