Measure twice, buy once
You can do it!
It just so happens I forwarded a Craigslist ad that had a 914 engine and trans for sale to him the other day.MarioVelotta wrote:Give Nate at Provolks a call. He is in Anacortes. You meet him at my placr for the megasquirt GTG.
turboedbug wrote: Run your finger across the bearing saddles if there is a lip......time for a line bore. The bearing dowel pin bores can sometimes be ovaled out if the rear main thrust went out of spec.
Replace the cam and lifters for sure (pitting is a no-no and it may have damaged the surface of the cam lobes if the pitting was on the lifters while it was running). If there are any slightest questions about something replace it as your end-stinks/gut feelings are often more correct than your rationalizations for not doing it are!Clonebug wrote:The lifters don't look to be in very good shape since I can see a bit of pitting in some of them.MarioVelotta wrote: Run your finger across the bearing saddles if there is a lip......time for a line bore. The bearing dowel pin bores can sometimes be ovaled out if the rear main thrust went out of spec.
Other than that it looks pretty good to me.
Clonebug
x2 for what turboedbug said.turboedbug wrote:do a stout bottom end......u could always do the top end later with out cracking open the case
I do not have ratio rockers and I hope to keep away from them due to the extra costs involved to add them.Coyote wrote:As I said before, if the stock crank show in your picture is fine, then use it. without adding counterweights. just balance it with a stock, non lightened flywheel. Use a Berg gland nut, or one that can handle a strong clamping force and that can be enough with 4 dowels.
In all cases you need to balance everything, because it's unbalanced parts that kill crankcase, bearings,...
You can buy unitech rods or scat I beam rods, already balanced end to end and fitted with ARP bolts.(from 150 to 160 $)
Balancing the pistons is also an easy task you can do yourself.
That's the level one. the cheapest.
The level two is to buy a counterweight crank. the best is the DPR, IMO.
The camshaft is another problem, because it's the last thing you have to choose. It depends a lof things, but any "cheater camshaft" can be a greater improvement over a stock one.
Have you ratio rockers?
