Update,
I ordered a new 1700 lb. Kennedy pressure plate from CB Performance today and Turbobaja sold me a CB super disc so I am on my way to a new Clutch.
I had a free day today so I went to work in the garage.
I pulled the turbo and the rear bumper off then removed the engine. A nice thing about working on it on a Saturday is I can go to my neighbor and get him to come over and help me with the heavy lifting.
He gave me a hand dropping the engine to the floor and then left me to my duties.
I removed the original PP and clutch disc and upon inspection both seemed to be in pretty decent shape yet. No heat related marking or any warpage that I could see. The Pressure plate was nice and flat when I put a straight edge on it. The clutch disc has some wear but there is plenty of life in it yet.
I will have to keep them around for a spare backup.
Even the flywheel looks good.
I noticed a little bit of oil in the bellhousing and with closer inspection it seems that the transmission main seal was leaking just a little bit.
I had a new one in my stash so I drilled a couple holes in the seal and put a screw in it..... grabbed it with a visegrip and tapped on the vicegrip with the claw end of a hammer to persuade the seal to come out.
After a bunch of pounding and a few new holes for the screw it came out. It was a lot easier to tap the new one in then pulling the old one.
All I have to do now is pull the flywheel and replace the seal since I am there already. I am thinking it wasn't what was leaking and that it was the transmission leaking instead. I will check it closer tomorrow or Monday if I don't have to work.
Now it is just a waiting game.
My new intake seals should be here Monday also so I will get them installed then I can put the cooling shroud back on.
I am planning on changing the wiring to the EDIS also while I have everything torn apart. I want to mount a wiring box to hold all my connections but I haven't found a good box that fits my needs or a good place since it is pretty tight under the body in back.
I do have an idea but I have to mount the shroud before I can see if it will work.
Clonebug
