Yes I know this from personal experience
Joxracing's 1966 Baja "The Resurection"
- Hedrock
- dustymojave
The impact is a a quicker and easier way, but if you don't have that capability...Joxracing wrote:alright, the one and only VW guy in my town said it would be even better to use an impact wrench.
And yes, its the baja with the leak, fords never leak
The drawback to using the impact is that you cannot accurately torque the gland nut. It's easy to break them if you overtorque. Undertorque and it can come loose, wobble, and destroy the end of the crank and the center of the flywheel.
A better way is to use a torque multiplier tool with a torque wrench.
http://www.thesamba.com/vw/classifieds/ ... ?id=271506
Wipe a little grease on the seal lip before installing the flywheel, and a little inside the pilot bearing in the gland nut before installing the clutch.
Richard
Lake LA, Mojave Desert, SoCal
Retired Fabricator
Retired Fabricator
- Joxracing
Hahaha yess.... she doesnt leak!!!!
(lets hope it stays that way)
A couple friends came over at about 4, droped the motor, put the new seal on, fitted the engine cage, and wired the lights up.
We were riding around in it by 8 o'clock.
For about 10 min we gave it a shake down on some offroad trail we found down the street, and came home, and realized we lost a part of the exhuast and a light cage, so we were fixing that up...
And my mom came out and she said that one of the neighbors called complaing, and the cops might be coming shortly., so we had to put it away...
But im seriously pissed off, because those ranger sideXside's, dirtbikes and 4wheelers drive around all day, and dont get called on nothing.
When my dad got home, he called the neighbor(which has a loud dirtbike and a ranger) and gave him a good earful...
But i cannot drive the baja around anymore
Now i have to be the prick, and im gonna call on every ranger and Dirtbike that rides by.
But... the important thing is..... IT RUNS AWESOME!!!
- 72bajaben
man that sucks....its pretty much the same where i live. dirt bikes and quads and loud muscle cars all over the place....but god forbid i drive the baja out in the 100 acres of sand behind my house.
Semper Fidelis!
Build Thread
Build Thread
- bajaherbie
- Joxracing
Alright, i got a few oil leaks, hardly anything to worry about.....right?
And when i hardly rev it, it sounds good, but when ya rev it a little bit, it sounds like its got a knock to it.
I really hope its not a rod knock, what are some charecterstics of a rod knock?
Oh, and are those oil leaks nothing, or should i pay attention to them?
- baja5
Always want to pay attention to oil leaks, at least I do. I hate leaving a trail. As for the Knock, rev the engine until you can hear the knock clearly, then pull 1 spark plug wire at a time off of the distrubutor. If the knock goes away of diminishes with a wire pulled the knock is most likely a rod and whatever wire is pulled is the cylinder in question. If the knock stays there, it is something else, maybe a Main bearing. If it is more of a tapping and doesn't go away it may just be a valve adjustment.
- baja5
