WBX-Enginecase : GW vs DJ
VW1300-NORWAY
Post by VW1300-NORWAY »
51MAN wrote:Thanks Joe
vw1300
If it has no extra "brace/web" across the alternator mount on the case then its an early case and a 2.1 crank wont fit without clearance and then the bearings are different..
Any 85/86 on, 1.9 or 2.1 case with the brace/web across the altenator mount will take a 2.1 crank ... 1.9 "DG" are easier to find in that respect.
I havent got a picture to hand.. and wont be able to get one for 2 weeks... maybe someone else can post a pic..
Hi, again!
Seems like the 1,9 GW engine case was made from '83 to '85. So this means the 2.1 crank won't fit, right?
Ove :)
pocketrocket
Post by pocketrocket »
I have installed a number of 2.1 (76mm) cranks in 1.9 blocks. You have to check for clearance in a few places. And you have to use the 2.1 P&Cs. The crank brg. sizes O.D. are the same. Rocky
VW1300-NORWAY
pocketrocket wrote:I have installed a number of 2.1 (76mm) cranks in 1.9 blocks. You have to check for clearance in a few places. And you have to use the 2.1 P&Cs. The crank brg. sizes O.D. are the same. Rocky
Thanks ;)
Ove
tencentlife
Post by tencentlife »
I've been lurking around here lately, gleaning info to help with my 2.1 rebuild. Guess it's time to weigh in.
1300, I've been dealing with this same problem. I tore down a replacement longblock from AVP that I've put about 90k miles on. Six years ago, when I was shopping for a longblock (OEM engine chucked a rod thru the roof at 160k miles. Install an oil pressure gauge, kids, it's the only way to know if failure is imminent), I chose AVP because they charged $600 for full cores when everyone else was demanding $1000, even though none of the others actually had any cores to build on anyway. Now that I've torn it down, I see why their core charge was cheaper. They built my 2.1 on a 1.9 case. It has the older pin-indexed bearings, and a bit of clearancing was done inside around the cylinder bores for the 76mm crank.
Although I tore it down in order to replace the low-compression Brazilian P&L set AVP used (see the piston story at GoWesty http://www.gowesty.com/piston_story.htm ), which had markedly less power new than the OEM engine had, even with such high miles (old engine still raised 160# compression at 6400' altitude, new one only did 130#), it's a good thing I did because the center main bearing was pretty trashed, all the Babbitt gone and deeply pitted copper showing. The #2 saddle had an obviously poor align-bore job, so now it's at RIMCO getting taken out to .040". They are going to supply me with some 2nd oversize T1 KS bearings for #2,3 and 4 mains, but leave the #1 alone since it mikes out fine. So I'm hunting down a .020" over, std. crank with oversize-thrust 1.9 bearing. Luckily Bob Donalds in Boston is going to come thru, he has some oversize thrusts he had custom made because of their near-complete unavailability.
Anyone know of any other sources for a bearing like that? Seems like there will be pretty good demand from now on. Rocky, perhaps?
