Page 2 of 2
Eaton M45
Posted: Tue Aug 28, 2001 7:55 pm
by vw505
hay man can you use that thing in a draw through ? like with a holly ? it would be for full race only!!
Eaton M45
Posted: Sat Sep 01, 2001 11:09 pm
by vw505
what mods do you do to carbs i have 40 dells,and 44webers. i am going to do the eaton super charger on a drag motor (t1 no tin). i have lots of resources to to do the set up . ????????????????? can you blow through a holly?
Eaton M45
Posted: Tue Sep 04, 2001 9:18 am
by Searoy
It could be a problem with your flow design.
Where are you taking the boost measurement from?
With the angles the air has to make to get into the intake port (a 360 degree turn) it's no wonder you don't get a lot of boost. It might be more effective (money wise at least) to redesign your intake instead of just getting a bigger hammer.
One idea I was bouncing around in my skull it to flip the blower upside down, keeping the pulley in the same location. This would place the body of the blower more centered, and direct the air upwards. That's 180 degrees less turn it has to make. Then build a plenum above the blower, of equal displacement to the engine, 2.2L (?) in this case. It should be the shape of a football, with the points of the ball ending at the runner connection. Half of a football (cut point to point) might work as well. That would involve the least amount of change to your intake system.
Yeah, the fan shroud is in the way. It was just an idea.
*** Teach a Man to Fish ***
Searoy
