cleaning a block...
Jim Andritsakos
Post by Jim Andritsakos »
Well, it's time to use the "heat removal" method.
The most easy to have is a propane torch but if you have oxy-acetylene torch is better.Heat with low heat the case around and under (if possible) the head stud for max of 30 sec but no less than that.Have the stud already double nutted and the engine case secured (engine stand?) and try to undo.If it does not spray again some PB Blaster to the threads and let it sit for 2-3 min try again if does not come out re-heat again.Usually all come out this way in the WBX engine cases that is far more tough than to t1/4.
Good luck
Jim Andritsakos
1973 1303 German look (project)
1975 ex Bundeswehr vw 181 (FS)
1988 T3 Syncro 16 doubledoor
1990 T3 Syncro panel
1985 T3 Syncro ambulance (FS)
1985 T3 2WD panel (FS)
