cannot get top end
- TALL
Just drove the car with the car set at 28degrees full advance. No change. What did notice was this.
When I am hard on the gas all the way up to any where from 3500 to 4000 rpm and hold at those rpms ( that is the usual point where it runs poor) for a second and then jump back on the gas it will contiue to climb through the rpm range until around 5500 where my shift point is set.
The change in sound reminds of a Honda v-tech motor. Very smooth at the start and then bam sounds the motor wants to blow. Only I have a noticable lack in power when this occurs to me.
- TALL
I just my 140's back in, I have no 145's I am also going to put my 55idles back in because I cannot get the idle to stop spitting and sputtering.
I am really starting to to think it is startvation problem. Because I can do what I ever I want in 1st and 2nd gear but going into third is the issue. I am thinking that I am draining my resvors faster then I can fill them up. My float levels are already at 10 and 32 but I am wondering if I could set them up to give me more reserve level and start filling them sooner. Like 7 and 27. (Random numbers)
When I stay on the gas with the 140's in and just contiue to get on the gas I get jolts of power, a subtle herky jerk feeling every few seconds.
- sparkmaster1
- sparkmaster1
are these carbs NEW or REBUILT?TALL wrote:I just my 140's back in, I have no 145's I am also going to put my 55idles back in because I cannot get the idle to stop spitting and sputtering.
i would consider soaking them in some carb soak..... if the fuel lines, tank, filter, etc does NOT clear up the issue....
- TALL
Here is the update.
I checked all the breath lines on my gas tank one was blocked out out of the four. Checked the flow out the tank from the bottom, no issue there. Blew air trough the hard line got some gunk but nothing much, all clear now. The rest of lines in the engine compartment were check for kinks.
I put my 55idles back in because I could not get the idle to stop spitting and snaping. Now runs rich but will deal with that later.
THE NEW... I took the car and ran it with no real improvement. But what I did notice is when I hold throttle at, say 3800rpm and keep the rpms steady at that rpm the car will surge. Going from the powerless bad sound to the good sound with a burst of power. THis only last a second and then back to crap. If I hold the throttle for a long it never gets better but just continues to surge.
IDEAS?
IDEAS?
