===MINI T Shock Tower Ideas===
Iowa Mark
I don't think so, Tim. I did these over lunch at work a long time ago and had to tweek them a little with my hammer when I got them home. There's more going on there besides just the offset shock towers. The lower shock location has been lengthed and lowered, and the shock is then bolted on the opposite side from normal. Those are lowered ball-joint shocks that are still too stiff for the light front end. I'm going to change to oil shocks and see if it helps any. The top beam is threaded rod , and the lower tube has been cut and rotated also. Way too much time in that front end.
