Apfelbeck head on flowbank (pic)
- raygreenwood
- Wally
Thanks Roberto!
And I know that was with two 36mm intake valves and one 42mm exhaust valve.
According to the book Apfelbeck wrote, two 38mm intake and one 46mm exhaust is possible!
Thanks for the update!
Walter
Paul Illick
- dstar5000
notice it was measured at 27" .......
Flow rate would be a little lower,
if measured at the normal 26".
Don
Don
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
- Wally
Hi Don,
Yes, you're right: Roberto went through the documentation of the SuperFlo machine and it has a re-calculation sheet from 27 to 25" that is a 3 or 4% difference. So what. Flow numbers are very high in his first (!) attempt anyway.
It should be mentioned that he measured flow WITH the manifold (a temporary one) and a throttle body (45mm). Normally the flow numbers of heads are quoted without carb/thottle body and manifold. This would be more than a 3-4% difference when left off.
Alpine, yes these heads were specificly designed for the type 4. The designer of those heads even stated that on a 2 liter type 4, 230 (DIN) hp would be possible!
As for production, it would be possible I suppose, but who would be willing to pay more than even the ('big daddy') Remmele heads cost? After all, besides the heads themselves, you would also need the special pulleys, intermediate shaft, intake manifolds and special camshafts. It adds up quickly also because its all custom. Consider just only the problem of different strokes with regard to your cam drive: you would need a different cam belt for each engine configuration and stock cambelts of car manufacturers only come in specific lengths; Its just one of those 'minor' problems, although I heard Roberto thought of something clever for that one...
Paul, I hope that answered your q as well. AFAIK, the cams will be belt driven from the pulley and probably with an intermediate shaft for the left cylinderbank (nr. 3 and 4) to overcome the otherwise too long of a cam extention.
Greetings,
Walter
Greetings,
Walter
Stroker 40 horse
- Wally
Not sure; all I know is that he used a stock 42mm 914 2,0 ltr intake valve to be used just for flow testing purposes as an exhaust valve. There's a wide range of aftermarket and OEM for valves, springs etc, so I'am sure he'll find appropiate ones.Stroker 40 horse wrote:What is the source for the valves/seats/springs/guides
Why do you want to know?
Walter
Stroker 40 horse
- bash555
check out these two books by Ludwig Apfelbeck
http://www.amazon.de/exec/obidos/ASIN/3 ... 45-1173325
also check this
thats the Porsche/TAG V6 Turbo Indy Engine ( i think)
too bad i cant read German
also check this
- Wally
Hi Bash555,
In the book you mentioned "Wege zum 4 Takt Hochleistungsmotoren" the molds and heads that Roberto has aquired are discussed and pictures of them are in that book also.
I have a german copy of the book and also seen the heads and molds in person. Very exiting stuff!
He's now working on the cam drive. It will take some time, but he will definately get there!
Greetings,
Walter
Greetings,
Walter
