Mech. fuel pump/rod
Trike Rider
Post by Trike Rider »
I just found out today waht one of those pmps cost,I got quotes of 100.00 to 210.00 after I picked myself off the floor I went out and plugged the holes said the hell with it. Ill run an elect. pump.The thing that makes me mad is that my first case choice didnt have that setup for the mech pump and if I had known this prior would have used that case and saved trouble.
At least now I know......... Dennis
Post by MASSIVE TYPE IV »
I have 10 brand new ones for 50 bucks each....... had them for 15 years on the shelf!
Trike Rider
Now you tell me.
Rip
Post by Rip »
someone help me out here. where is the fuel pump located? I don't remember taking one off of the long block I got. Nor do I remember seeing it in jakes rebuild video. got a pic any one?
thanks
BluBus
Post by BluBus »
it's in the lower right hand side of the engine towards the front of the car. below the starter.
Rip
Post by Rip »
under the pistons/liners?
between the pushrod tubes?
Rip
Post by Rip »
I have a 914 2.0L case, it has some sort of machining on the side of the bellhousing but nothing there. could it be possible that mine doesn't have a mech. fuel pump?
BluBus
Post by BluBus »
It's not on the bellhousing it's near the #1 piston. Mabe you don't have the case for one.
Rip
Post by Rip »
does anyone know for sure which engine cases came with mechanical fuel pumps?
Bobby74
Post by Bobby74 »
The ones that came with carbs :lol: Usually: AW, GD, CB, 1700, 1800 bus cases. Pretty much anything '74 and earlier VW.
Alaskabug
Post by Alaskabug »
OK, been following this thread and have to ask.
If the fuel pump/boss mount on my '71 411 1.7L t4 case is factory blocked off (fuel injected engine), do I need to worry about any of this pluging oil galley drains?
Should'nt the oil pressure be good without doing anything in this area?
I just finished pulling all the factory pressed in oil galley plugs, drilling, tapping and fitting new anodized aluminum npt plugs. Am I over looking something?
Alaskabug
56 oval t4 dtm
Bobby74
Post by Bobby74 »
If its an FI case, you don't have to worry about anything. There is no mechanical pump, and no pushrod to activate it.
Its only when people remove the guide in the mech fuel pump cases (carb'd) that you run into this drain issue.
-Bobby
Alaskabug
Post by Alaskabug »
Whew!!! Thanks Bobby.
John
For years I never saw the issue till one day when a new rebuild had zero oil pressure....figured it out pretty quick
njv
Post by njv »
hi
so on an fi case the oil in the rh side of the case just bleeds down over the lifter gear there is no little fuel pump chamber with a drain to the case bottom is there somebody please?
