T1 crank into a T5 case?
Farmer, You must use t-1 end play shims & yes they only cover part of the brg & part of the flywheel, but its the only way unless you make shims with T-1 I.D. & T-4 O.D. & machine & weld a ring on the flywheel to make it T-4 size at the shim area.Thanks Rocky
OK ! I think the reason why I did´nt understand it in the first round was tha I have been consentrating on 1,9 cases.
Thanx.
Thanx.
