Best Type 1 Engine Rebuild Configuration
- James2
I would run stock dp heads, Kadrons, Engle 130 cam, 12.5 CR and 94mm slip in Pistons.
gleason
quote from James2 "I would run stock dp heads, Kadrons, Engle 130 cam, 12.5 CR and 94mm slip in Pistons."
?????? I hope you're just kiddin me....
- James2
Just kidding, there are no slip in 94's, you'll have to machine them in.
gleason
Is 12.5 cr the max I can go?
Thanks for the feedback...
- bedlamite
There are a couple of swap meets in the summer, one in Milwaukee and one in Madison. I have found some deals there, but mostly we're stuck with mail order. Whatever you do, stay away from MOFOCO in Milwaukee.there isn't much for VW stuff much less perfomance around here
If you can make black marks from the apex of one turn to the braking point of the next, you may have enough horsepower.
bigbad
Mine is a vert too. This guy in Tallaapoosa is doing all the body work. You might know who he is. (-8
