I sell any kinds of 944-Brakes for bugs/Karmann/181-Thing for germany on my page
www.wolf-lunacy.de
944 Trailing arms in Type I,II,IV or 181
Single Cab
Nice work. Are your products TUV approved and can you send me a pricing sheet? I have a '65 transporter and a '74 Thing (type 181).
Thomas
Thomas
- kcnaz
Re: 944 Trailing arms in Type I,II,IV or 181
Did you find any wheels, I assume the Thing was fitted with off-road wheels?RB Thing wrote:Thanks for the help! I need the extra width because they are going on a Thing and I will be using wider finders. I just purchased a complete 86 Turbo suspension so I also get the Turbo brakes. I'm engineering a fit to weld the Porsche bigger spindles onto a set of Thing spindles to keep the steering and lift. If that works out as I plan, I am looking into doing the same to a Bug.
- kcnaz
test fitting the 356 spidles I found the left support bow was bent. I built a press and took it apart, bad news and good news. Bad news it is very bent, good news is the VW beetle spindles I took apart are good and the vw support bow will interchange with the porsche........
look at the difference between the axle....Porsche is much bigger.
