hmmm... seems kinda high to me:
[email protected] rpm
torque [email protected] rpm
bmep was [email protected] rpms(!), @ 8.5:1 c.r.
this motor might be detonating on the streets of so cal
why? because the cylinder pressure of a factory dual-port type 1 engine(7.3:1) is only about 123 psi... and yeah, i changed the cam timing on your 1915 by 10 degrees in both directions, and the bmep only differed by around 10 psi or so... when i put the c.r. at 7.3:1, the bmep was 178 psi, because the v.e. is still 85%.
you might be able to get away with it easier in north georgia, because of all the moisture in the air, and the better gasoline.
i put the carb @250 cfm per barrel, because i don't know what the flow is, and i did not factor in the ratio rockers, because i can't find an easy way to do it with this program... even w/225 cfm per barrel, there was only a 5 h.p. loss at the peak.
if i were you, i'd do a search on the clf for all the 1914 dyno stuff that has been run.
dan
oceanstreetvideo.com
the smaller bore motors really limit valve size which will limit your overall power output. the motors that do have small bores tend to have mutivalves per. cyl.(4 valves)to make any kind of hp. vw's only have 2 valves per. cyl. so you may limit your hp. potential
jmho.
