Regardless of what size motor you have, you really should use stock exhaust if your using a stock (i.e. no race mods) motor. Especially if your going for reliablity.
Your bus did actually come from the factory w/ the type 2/4 "pancake" motor. I don't know what the stock size was though. Unless your wanting to build a "performance" ($$$) motor, stick with stock.
New Exhaust & Blown Valve Gasket?
dallas,
your van came stock with the type IV "pancake". it was the first year.
you can still get a stock one. like i said before, i bought the same nuffler, and i do not think it works properly, either. it probably flows worse than the stock unit.
here is what the muffler looks like:
http://store.cip1.com/Merchant2/merchan ... 2-06-01-02
scott lyons
scott lyons
Thanks again. I will run this one for a bit, and if it proves to be, as you guys have said, a turd, I will go back to stock.
- vwdreams
s&s headers with a stinger and no baffle.
sounds good to me
sounds good to me
