Crawdad wrote: ↑Fri Dec 04, 2020 10:20 am
My NEW worry (I worry a lot - worry twice, build once) is about the other valve – the relief valve at the pulley end – which controls the pressure at which oil gets sent to the cooler. Using pressure as a proxy for temperature isn't ideal, especially if using modern, light-viscosity synthetic oil, which will trick the system into thinking the oil is warm when it isn't. Making matters worse, the stock-strength spring doesn't seem to be available anywhere, only the "pressure boost" springs that have the effect of making oil go to your cooler at a lower temperature (compared to a stock spring). For a daily driver, that seems like a really bad idea, especially if you've got a couple gallons of oil to heat up. The obvious solution is to use a real thermostat. But I'm clinging to the idea of using the stock cooler, rather than adding yet more plumbing and expense. If my oil isn't getting up to temp, I'll have to rethink.
I'm going through this thread and have to ask a few questions and point out something:
above, in your quote, you say the pressure boost springs make the oil cooler. Not quite. The pulley side relief valve closes the oil path to the cooler when pressure is high (cold oil) and opens it when oil is warm. Increasing the pressure that this happens at only serves to cook your oil. Hense why bigger oil pumps dont actually cool your oil more unless you add external coolers for the oil to go through.
My question is: Why do you want more oil pressure? Without re-reading your posts, I'm remembering you talking about going from 60psi to 80psi on the relief. Again, why?
On hydrodynamic bearings (plain bearings like we use in a bug engine), the crank isnt supported (lifted) off from the bearing by the oil pressure. The oil pressure serves to get the oil to the bearing and then once its there, the rotational speed of the crank is what forces it between then bearing and the crank. The supply pressure has very little to do with this hydrodynamic wedge of oil, its all in the speed difference between the two surfaces.
Yes, the pressure gets the oil to where it is needed and higher oil pressure will supply a little more oil, but there is only a certain amount that will be able to flow through each bearing unless you reduce the viscosity.
friction head = (4x flv^2)/2gd
f = friction coefficient, l = length of system, v = velocity, g = gravity, d = diameter of pipe
note that velocity is squared in this formula
so going from 60 to 80psi = (8/6)^2 = 1.78, which means that your pressure increase leads to 78% more friction losses on the system - or, 78% more power needed to drive the oil pump = more engine losses and more heat pushed into the oil.
Again, why would you want this when you are getting all the oil to all the points that you need it and the velocity of the parts is doing the rest.
For reference, I run 15W40 with 26mm oil pumps on all my engines except my 2332 street beast, which I use 5W30 with a blocked off stock cooler and a single smallish external cooler and a 26mm oil pump.
