Been too hot to spend time outside especially after yesterday's work fixing a mistake I accidently made. The wife and I had to dig a ~6' long trench about 6' deep through one edge of the flower bed. I was cutting some roots from a tree I had removed last year but the roots were still alive and trying to grow another tree. The reason the roots were above ground in that area (actually there was another root that I had removed but got a way with it) was that they went over the tubes for the sprinkler system (3 tubes stacked on top of each other) and I nicked the top two tubes with a cutoff saw so we had to cut out the bad sections and fix the watering system. The weather here is close to the 90° and the humidity is high... even in the garage.
I did get the bolts for the tool a few days ago. I wanted to use 1/4" dia. bolts but 3/16" looks like a better choice. I also couldn't get 3 3/4" or 3 1/2 length bolts that were fully threaded. All the bolts I could find close by had "shanks" on them that could cause clamping limitations. I finally drove up to the next town and got what I wanted. Now I have to locate then drill all 8 holes in the sides of the main tool then weld the heads of the bolts in place... from the underside as there is literally no room on the top of the tool to accommodate the head of the bolt.
