vw sedan 1600i (Mexico) to 1776cc?
juanpablo1969
Re: vw sedan 1600i (Mexico) to 1776cc?
Post by juanpablo1969 »
how post pictures in shoptalkforums?
juanpablo1969 wrote:maybe in german models. but type1 sedan 1600i and Golf/Vento Mexican injectors are phisically the same, only change injection capacity!
I recall the Mexican manifolds injector mounts to be ~14mm ID, with injector bases to match.
(Had a complete setup I passed on to a good home, as I'll probably never build a T1 again)
If you do decide to go there, it will probably just work if you went 1835 with the right sized injector.
You would have to worry about compression ratio, as you don't want to run too much deck.
juanpablo1969
ok, I intend to leave 7.8 CR, 1.5 mm (0.060") max deck height....... I'll have to modify a little bit the combustion chambers to achieve this......My idea is just want to increase cc´s and keep everything else the same, I worry about running lean at WOT , for that I have to use a ballast resistor in CHT sensor or maybe 1800i injectors, but would have to do the appropriate tests for sure!!
Post by Marc »
juanpablo1969 wrote:how post pictures in shoptalkforums?
viewtopic.php?f=18&t=127818
juanpablo1969
In the pictures appear type1 sedan1600i, inlet manifolds, injectors and digifant ......Additionally Vw Golf 1800 injectors...all pieces are compatible!
juanpablo1969
red injectors mexican vw golf 1800cc vw ...
juanpablo1969
Vw Golf 1800 digifant, same pins, same efi system type (differents readings) water temp sensor
Ah, so it seals on the body of the injector.
Give it a shot.
juanpablo1969
Piledriver wrote:Ah, so it seals on the body of the injector.
Give it a shot.
Hi again, after cold winter I rebuilt my 1600i engine with 90.5 AA pistons, I will Use with 8.0 CR, I want use the same stock 1600i digifant ECU and injectors....Now I need a decision, use stock 30x33 valves size or increased to 32x35,5......Who is better for my 1776 efi??
