If looking at back of flywheel, it would be 3:00 from TDC TOOTH... Right?
Dale
Making a trigger, which tooth to remove..?
- Dale M.
Re: Making a trigger, which tooth to remove..?
well the sensor is to the right of the case centre line so 90 degrees would be about 4:00/4:30 maybe, with the crank at TDC
- Dale M.
You are close to correct.... But it all related to what TOOTH (or hole) is "visible" in sensor port this is the TDC TOOTH (crank at TDC), and missing tooth (or hole) will be 90° or 9 teeth before TDC TOOTH (or at 3:00 from TDC TOOTH which would be 12:00 when calibrating flywheel) ...andy198712 wrote:well the sensor is to the right of the case centre line so 90 degrees would be about 4:00/4:30 maybe, with the crank at TDC
Also as side note, think one may want to have flywheel balanced after all the drilling....
Dale
Right yeah I'm on the same track, when I look through the sensor hole it looks at about 1o'clock position on the flywheel, and my missin tooth wants to be 90degrees from that mark.
The only question is, if 90 degrees is between a tooth, perfectly, do you remove the one closer to the sensor or further away?? That's my thoughts... Will pop it back on the engine tomorrow and start marking it out
Oh yh for sure balance. That's why I did it now before I get it all balanced
Cheers Dale!
Andy
Cheers Dale!
Andy
i still need to do it! maybe tomorrow!
well, i removed the bit between the 9th and 10th hole from the TDC one in relation to the trigger, so 90 degrees from the trigger
will get it all balanced now and see how i go!
thanks guys
Andy
thanks guys
Andy
it works fine
i drilled and tapped an M6 hole next to the señor hole, put in an M6 bolt and the sensor with a nut either side of it for fine tuning and all works as it should.....
need to double check it with a timing light to see where i'm at with that but so far, so good
It was a couple degrees off when checked with a timing light but trimmed that easily
literally just a couple. 2 if memory serves me
- woodsbuggy1
Sounds like you have it figured out, EDIS has worked very well for me and the millions of vehicles that it was originally installed on. Do not be afraid of EDIS, the components have a much lower failure rate than any COP system that I have seen. Keep up the good work, cant wait to see your success story.
Kenric
Kenric
