New injection fuel rails
- Devastator
Re: New injection fuel rails
Those look cool! I don't have an injector retaining clip integrated into my design. I like it!
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
- panel
Those are sweet!
- MarioVelotta
[email protected]
[email protected]
- MarioVelotta
I'm torn. Should I stick with my initial plan of using O-ring sealed fittings or stick to 1/4" NPT. The NPT fittings are about $3 each. The o-ring fittings are about $10 each. I'm leaning toward the NPT to keep conversion cost down.
How would you do it?
[email protected]
[email protected]
NPT for the win!!!
- Devastator
X2!Clonebug wrote:NPT for the win!!!
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
- Stripped66
Some of each? The NPT is cheap and simple. The ORB allows for 1/2"-1" less total width (including the hose-end), if space is a concern.MarioVelotta wrote:I'm torn. Should I stick with my initial plan of using O-ring sealed fittings or stick to 1/4" NPT. The NPT fittings are about $3 each. The o-ring fittings are about $10 each. I'm leaning toward the NPT to keep conversion cost down.
- MarioVelotta
Here is my thought. I can have the ports drilled for a 7/16-20 port, which is a .39" hole. This would leave it open to both sizes and I could finish it either way before shipping.
Here is the new geometry to save on some machining cost. Pictured with -6 o-ring fittings. Making sure they fit because they are much larger.
[email protected]
[email protected]
- kubelguy13
will there be enough space for the fittings to tighten next to each other?
"Being ready is not what matters. What matters is winning after you get there."
- MarioVelotta
Made sure I was good there,
[email protected]
[email protected]
That's tight!!!!
What if the fitting bottoms out tight when the high point is vertical on both fittings??
- MarioVelotta
These are the 0-ringed fittings. They offer a little give in positioning.
[email protected]
[email protected]
- Devastator
Can you post a link to the fitting?
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
- MarioVelotta
This would be the 0-ring fitting type
http://www.summitracing.com/search/part ... N%20o-ring
This would be the NPT fitting type
http://www.summitracing.com/search/part ... ze/minus-6
Sorry I didn't get to your email today. I'll try to get to it tomorrow
[email protected]
[email protected]
- Devastator
No problem.MarioVelotta wrote: Sorry I didn't get to your email today. I'll try to get to it tomorrow
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
