They are just off the shelf Bilsteins from Summit Racing - I tried to get the Konis and had a hard time sourcing them. Ordered them from Summit and waited about 2 months and they just kept back ordering them so I just gave up and went with the Bilsteins.JWP wrote:I was curious if the OP had a special set or if they were an off the shelf version from Bilstein.
Vintage Road Race Ghia...
Re: Vintage Road Race Ghia...
Thanks for the info. I've had bad luck with ordering Bilstiens in the past so it's nice to know a reliable source.
Beautiful build!
'12 VW Jetta TDI sedan- MPG queen
'76 Ferrari Dino 308 GT4- Garage Queen (turbo boxer swap)
'73 Datsun 240Z- Autox'er
-Jay Gilling
-Jay Gilling
awesome work! Will be watching for progress
- Fiatdude
I believe I am going to switch over to coil overs in the rear and use these QA-1's
http://www.summitracing.com/parts/hal-dd401
I've ran QA's single adjustables on the rear of my oval and really liked it
that car is to beautiful to race!!!! lol what you gonna do when somebody bends it or rubs it./??? the sme thing I did when I scratched mine up hahah
Thanks for the compliments - I'll keep the thread updated with progress. A friend of mine mounted the trashed 205/50 spec miata hoosiers on some stock 4.5" VW wheels (obviously not right it is just to roll the car around). They look like bloated compact spares - We'll see how that adventure goes.
The pictures make the paint look nicer than it is. Its actually just an old ford truck blue shot as straight enamel, no clear, no wetsanding, no buffing...
First, rub them back and then fix it duh - -r1cpowdercoating wrote:that car is to beautiful to race!!!! lol what you gonna do when somebody bends it or rubs it./???
Ok - so it is totally ridiculous (and as a disclaimer, completely unsafe) to stuff a 205 tire on a stock 4.5" rim. But...at least as it sits, to facilitate a test fit and roll the car around the 205 Hoosiers just might work on the track with a correct width wheel
. The significantly smaller diameter (23" from nearly 27" stock tire) helps immensly. That is an instant 2" lower from stock + 2.5" drop spindle gets it 4.5" lower without even trying. I still have the adjustable beam to fine tune from there. If I try to slam the fenderwell over half the tire (like the super slammer guys do) - then no way, thats not my point anyway. But it least it doesn't stick out past the fenderwell and for racing, this should do just fine. Now I just need to get some proper 5.5" rims and have at it.
sweet! where did you get the 1.5 dropped spindles? i dont want the 2.5in drop they sell everywhere...
Sorry, my typo got you excited - they are CB performance 2-1/2" - edited.andy198712 wrote:sweet! where did you get the 1.5 dropped spindles? i dont want the 2.5in drop they sell everywhere...
i drilled my rotorsfor the 5 lug ford pattern then found some BBS wheels off a mazda rx7 poder coated them and thats what I run. lood great on the car and they are the same offset as the vw wheels.
- Jadewombat
My friend's ghia had to be raised back up a little with adjustable beam after dropping with spindles. Rubbed a bit on corners and braking otherwise with the spindle drop.andy198712 wrote:sweet! where did you get the 1.5 dropped spindles? i dont want the 2.5in drop they sell everywhere...
my thought exactly
- FJCamper
Hi Cefolar,
We've been running 50 series tires on our PanAm Ghia, and two things are very apparent.
1. They do a great job of lowering all by themselves and handle great.
2. They put us at a great disadvantage for top end with our 4.12 r&p.
FJC
FJC
Yeah - the smaller tire diameter is certainly an issue with that shorter gear and something we kept an eye on. Fortunately, Mike at Rancho Performance setup the new transaxle (R/P and gear ratios) to compensate for the smaller tire diameter. Calculated top speed at 6500 RPM was around 140 mph - doubtful it will ever see that except maybe the Sebring or Daytona.FJCamper wrote: They put us at a great disadvantage for top end with our 4.12 r&p.
