On gearboxes with countershafts, or planetary gearboxes like the lencotrinity wrote:I open one transaxle, I saw a number of gear, from input shaft that meshed in the mainshaft and on the mainshaft 4th counter gear there is intermediate shaft with gear, at the end of that shaft also got one gear which is the pinion gear meshed in the ring gear. now which of those gear meshed i need to calculate to get the overall gear ratio for the speed gear i choose example is 3rd gear speed. the number of teeth of them.
3rd gear = 36/28= 1.285
Intermediate shaft with gear= 34/30= 1.133
Pinion and Ring gear= 67/17= 3.941
which of these i need to calculate to get the overall gear ratio for 3rd speed gear.
you need to multiply the ratios of meshing gear sets together.
So in the above example,(just guessing without a picture of your example),
1.285 x 1.133 = 3rd gear ratio.
Them multiply by the R&P ratio gives the overall ratio.
Volksies are very simple,
you just divide the driven gear (DN), by the driver gear(DR) which gives the ratio,
them multiply by the R&P ratio gives overall ratio.
