Page 2 of 5
Re: 091 build for turbo bus
Posted: Thu Aug 30, 2012 4:37 pm
by kubelguy13
my main bearing is spinning when i try to undo the nut.
I need a press to squeeze the case and hold it while I get the main pinion bearing nut off.
Posted: Thu Aug 30, 2012 5:30 pm
by Henryhoehandle
From what I can tell, it looks fine. Do all of the teeth on the pinion look as good as the "top" ones? There is something on the bottom ones or maybe a reflection or whatever??
Posted: Thu Aug 30, 2012 5:48 pm
by kubelguy13
Henryhoehandle wrote:From what I can tell, it looks fine. Do all of the teeth on the pinion look as good as the "top" ones? There is something on the bottom ones or maybe a reflection or whatever??
It looks like black oil stains or just oil I think.
Can't get it out yet.
Posted: Sat Sep 08, 2012 12:23 pm
by kubelguy13
I don't have a press at home and my pinion nut is just spinning the bearing.
Can anyone tell me how to stop the bearing from spinning so I can get this big nut off?
Thanks
Posted: Mon Sep 10, 2012 3:29 am
by Henryhoehandle
That is tricky. Since it is spinning, then the case is shot or at least needs re-sleeved. Therefore, I use a die grinder (with a GOOD quality carbide burr bit- flat on the end works best) and grind through the nut (do it where the lock groove in the bearing is). After you grind through most of it, then you can use a chisel and crack the nut. You will most likely destroy the bearing threads, but it doesn't matter as you should probably replace it anyway..
Posted: Mon Sep 10, 2012 9:24 pm
by kubelguy13
Henryhoehandle wrote:That is tricky. Since it is spinning, then the case is shot or at least needs re-sleeved. Therefore, I use a die grinder (with a GOOD quality carbide burr bit- flat on the end works best) and grind through the nut (do it where the lock groove in the bearing is). After you grind through most of it, then you can use a chisel and crack the nut. You will most likely destroy the bearing threads, but it doesn't matter as you should probably replace it anyway..
Thanks!
Sounds hardcore. I'd like to reuse the case. Too bad about having to resleeve.
Posted: Tue Sep 11, 2012 3:58 am
by johnwalklett
You can just split the nut with a chisel it makes less mess than a die grinder
Posted: Tue Sep 11, 2012 9:10 am
by gaston
kubelguy13 wrote:Henryhoehandle wrote:That is tricky. Since it is spinning, then the case is shot or at least needs re-sleeved. Therefore, I use a die grinder (with a GOOD quality carbide burr bit- flat on the end works best) and grind through the nut (do it where the lock groove in the bearing is). After you grind through most of it, then you can use a chisel and crack the nut. You will most likely destroy the bearing threads, but it doesn't matter as you should probably replace it anyway..
Thanks!
The guy at Rancho I talked with told me that they resleeve every case. So nothing bad.
Posted: Fri Dec 28, 2012 5:42 pm
by kubelguy13
Posted: Fri Dec 28, 2012 5:58 pm
by kubelguy13
The reverse gear shift fork was missing . It goes on the pin in the back of the photo here.
Posted: Sat Dec 29, 2012 5:42 am
by Henryhoehandle
The wear on the shift housing won't hurt anything. If the bearing fits
loose in the bore then this can be sleeved as well.
You will want to install a thrust
plate under the nosecone as this
will prevent the mainshaft from moving.
Posted: Sat Dec 29, 2012 11:10 am
by kubelguy13
Henryhoehandle wrote:The wear on the shift housing won't hurt anything. If the bearing fits
This is good news. Where is a thrust plate available for a VW 091 gearbox?
Cheers
Posted: Sat Dec 29, 2012 12:04 pm
by Henryhoehandle
Posted: Sun Dec 30, 2012 12:42 pm
by fastback
does anyone have more info on resleeving pinion bore?
Posted: Thu Jan 03, 2013 3:31 pm
by kubelguy13
fastback wrote:does anyone have more info on resleeving pinion bore?
rocky jennings does this.
http://rockyjennings.com/
