aircooledtechguy wrote:I have only seen this when the directions are not followed. I have almost 16 years on by bus tank, 6 years on my Square tank and countless client tanks with not a single come-back. Prep and ensuring that there is absolutely no moisture left is key to success. That and allowing a full 96 hour cure before adding fuel. . .Chris V wrote:I did several tanks with POR-15 years ago and all of them have some problems with flaking off either a little or a lot...some in giant sheets. I don't think I'll be using it again.
Ummm its been a few years since I did my Beetle tank but I don't recall this being the directions they provided...
I am not saying your way won't work...I just want to point out if anyone does this and it peels off then the company is not going to help the person out since this is not the way they tell you to do it. They say to use the Marine Clean, Metal Ready, and then the POR-15 tank sealer.aircooledtechguy wrote:If you have several tanks to do, I would do them assembly-line-style and save huge $$$. If you have 4 tanks to do, here's how I have done it. . .
Clean each tank with acetone to remove the varnish. About $20 worth of acetone should do all 4. Rinse all tanks with water thoroughly. Get a bottle of OSPHO (phosphoric acid) at the hardware store (about $15). You can use 1/2 a bottle in one tank, then after you finish with the first tank, empty it into the 2nd tank and re-use it. Do the same with the 3rd and 4th tank with the other half of the bottle. Rinse the tanks thoroughly with water and immediately dry them using a heat gun (best) a hair drier (2nd), hell a leaf blower will even work.Make absolutely sure they are 100% bone dry.
Then get 2 quart cans of POR-15 tank sealer about ($35-$40 each). Use the 1st quart in the first tank and coat it as normal. Drain it back into the quart can (it only takes about 1/4 of the can to coat a tank). Then dump the remaining amount into the 2nd tank and coat it. Repeat this for the other two supplementing the lost sealant with the 2nd quart.
If you don't get careless and spill too much, you can actually coat about 5 beetle tanks or 4 bus tanks with 2 quarts of sealer if you do it all at once and are prepared. You'll have just over $100 into it, but you'll have all 4 tanks done at a cost of about $25-$30 each. Not expensive at all, but not free either. . . You gotta pay to play!!
If I was going to buy their sealer and then not follow the instructions then I would use something cheaper. Masterseries is supposed to work as a gas tank coating, and its much cheaper..They tell you what to prep the tank with...And it's not stuff they sell like the POR-15 company...
