my stock 1600 dp turbo build!
1938vw
Re: my stock 1600 dp turbo build!
Be happy with 90bhp
Clonebug
No you won't........boost is an addiction.
You will always want more.
1938vw
It's bad enough in my golf tdi! Loooove the boost!
1938vw
So yesterday I added the deep sump (inc. turbo oil drain return), tin wear, alternator, up rated silicon intake boots, intake manifolds, and renault 5 carb. The mountain of silicon goodies and rubber fuel hoses i ordered didn't arrive though
A word of warning when fitting a deep sump: on the crank case is the oil pick up, it's bolted down inside the case, this bolt becomes impossible to remove once the case halves are together. Sods law, to fit my extended sump correctly it needs to be removed and replaced with an Allen key head bolt so it can be tightened through the holes in the extended sump!
bratjie
Hi 1938vw, came across your build, you're doing well so far, I have just completed my 1600dp Turbo build with alsmost the exact same spec as your's, exept that I will be running a T25 Garret with internal w/g and single dell 36, stock dizzy, had some other stuff done too. What hp are you expecting to get from your build?
Clonebug
What about your pulley tin???
You need that in a bug to keep the engine cool.
1938vw wrote:So yesterday I added the deep sump (inc. turbo oil drain return), tin wear, alternator, up rated silicon intake boots, intake manifolds, and renault 5 carb. The mountain of silicon goodies and rubber fuel hoses i ordered didn't arrive though
1938vw
Hello there! Well I have to say, I'd be happy with 70bhp I just wanted to see if I could do it. Maybe in the future I'd like to build a bigger better engine or maybe a small engine with built proof parts again just to see if I can. The "200HP 1600dp" is a very good thread, of you haven't already, read that!bratjie wrote:Hi 1938vw, came across your build, you're doing well so far, I have just completed my 1600dp Turbo build with alsmost the exact same spec as your's, exept that I will be running a T25 Garret with internal w/g and single dell 36, stock dizzy, had some other stuff done too. What hp are you expecting to get from your build?
Any idea what power you are after?
1938vw
Oh god yes, I'm doing all I can to keep it cool, even have a thermostat controlled oil coolerClonebug wrote:What about your pulley tin???
1938vw
No pictures to update with, sorry didn't take any, was too busy doing this!!!!!
http://www.youtube.com/watch?v=uaRjIDZM ... ata_player
- yvre
Cool! Well done. Now the fun part begins.
1938vw
13window
Great work.
Might start a thread on my 1600 build
1938vw
Zander, thanks
13 window, thank you and yes, do it!
BARTMAN360
Thats cool, I know the addiction as I have it too. All that math on the first page figuring compressor size made my head hurt. I just went to the junk yard and picked one that looked like it would work. The funny thing is my turbo specs are almost exactly the same asyours and we basically have the same engine..... Too funny. Keep up the good work. You will love the boost. I got over 25 miles per gallon (freeway) on my first tank.
Bret
Bret
