Did you use the stock mexi valve or another one?
And did you port your throttle body?
Mexican throttle body anatomy!
- Chip Birks
Re: Mexican throttle body anatomy!
Mine came from a jetta or something similar. Just a 2 wire bosch valve. All metal body. I did not port my TB at all. I ran the larger vacuum port into the manifold above the throttle plate, this smoothed things out a lot. The motor had good throttle response. The Mexi stuff was just too restrictive overall for my goals, and displacement.
- yvre
Do you mean you just bypassed the throttle body directly?Chip Birks wrote:I ran the larger vacuum port into the manifold above the throttle plate, this smoothed things out a lot.
- Chip Birks
Yes and no. The port mentioned is actually located just above the throttle plate inside the TB. I found that it helps with early throttle response.
- kuleinc
I just checked my (I think Mexi TB) and it is a straight through shot, no "this thing doesn't even open until 1/3rd throttle" crap here...
My bad, I have a german EFI intake and TB...
1995 BMW 318ti with M3 Motor (Mine)
1994 BMW 325i Sedan (Hers)
1968 Baywindow Camper (Parts Bus)
1971 Westy Baywindow (EFI project...)
My build thread: viewtopic.php?f=14&t=137593
